HI all,
I do a lot of ornaments etc, and I have been using a pad sander and a downdraft box, in reading some of my older issues of SSWC I saw a few places where people used the mouse style sander as they wern't so aggresive to prevent breaking pieces, anybody using this and any reccomendations for a brand that is good?  Thanks
Bill
I sand before and after with my Bocsh random orbital sander and have never had any issues with breaking ornaments or anything.. I use the dollar store anti slip drawer liner things to sand on and the grip the wood so it doesn't go flying, LOL I turn the sander speed down on small or fragile stuff.. and lightly place the sander onto the projects and just go easy with it.. Everything I make gets sanded before and after cutting.. Look at my website and you'll see all the things I make ( sand ).. some are quite fragile..
I sand llightly befor I ake any fretwork. then after cutting I go ofer it again with a mouse sander 220 grit I then use a mop sander that i madeas stat5ed berfore don't put toouch pressure on it . all most all fuzzy are gone with no breakage.
IKE
Thanks folks
I saw in one of my past issues of SSWC that someone used a ezlock in their dremel with some sort of small 320 grit buffer things so I sent for some to see how they work. I also sand before, I was just concerned about sanding after and I had seen where they used a mouse sander that was mentioned above. Have never tried the torch,
Thanks
Bill
I saw this on a YouTube video a few years ago. It’s a piece of leftover plywood with a finish, over that is on of those grippy rubbery cloth things. It is held together with the wood strips on either side. The rubber is not attached any other way. I sand everything on this with my ROS. Even my fine fretwork.
On 12/3/2020 at 7:00 AM, Paladin said:
The sand-flee drum sander works great for sanding after something is cut.  I run all my smaller projects across it and it does a really good job.
What grit are you using for the drum?
I pre-sand all of my wood before cutting.  I also use the Sandflee, but mostly I use a MAC MOP 240 grit. Yes even on my delicate ornaments.
I just support the ornament on a piece of wood, It removes the majority of any fuzzies that I have.
