DrunkenMonkey Posted December 4, 2020 Report Posted December 4, 2020 Hey guys and gals, I did a little bit of scroll saw work in woodshop classes back in the day, but its been a while so I'm hoping I'm not biting off more than I can chew with this project. I'm trying to make a portrait of my girlfriend and I as a Christmas gift. I have someone else converting a picture to pattern for me because I wasn't happy with my own attempts. If anyone is able to offer any tips for me I would be so appreciative! Suggestions for type of wood? Blade? Mounting it (thinking mount the cutout onto something dark(?) and make a frame of some kind)? General newbie scroll tips? Thanks in advance to anyone who can offer advice! I'm really nervous but also super excited to get (back) into this! OCtoolguy 1 Quote
John B Posted December 5, 2020 Report Posted December 5, 2020 Mark, I don't know in which part of the world you are from, but it seems that the preferred timber for portraits in the US is Baltic Birch ply either 1/8 - 1/4" In Aust. Hoop pine ply is the best. Most portrait cutters glue their cut out to a black or coloured piece of ply, some time using coloured felt instead of paint. If you are uncertain about making a frame, a lot of people purchase a photo frame and make the scroll work the appropriate size. Hope this give you a kick start OCtoolguy, NC Scroller and Roberta Moreton 3 Quote
ike Posted December 5, 2020 Report Posted December 5, 2020 I use 1/8 Baltic berch with a cheep ply backing painted black. the cheep ply is floor underlayment It use to be $15 per sheet but the way wood is going up it's hard to tell what it is now. I use a #3 olson blade . IKE Foxfold 1 Quote
Ctutor Posted December 5, 2020 Report Posted December 5, 2020 Cheep is not the way to go for something like a portrait. Try Ochooch hardwoods or some other supplier even Amazon and get some good ply. The uderlaiment will spliinter and make things look . . . well cheep. Quote
Foxfold Posted December 5, 2020 Report Posted December 5, 2020 (edited) 1 hour ago, ike said: I use 1/8 Baltic berch with a cheep ply backing painted black. the cheep ply is floor underlayment It use to be $15 per sheet but the way wood is going up it's hard to tell what it is now. I use a #3 olson blade I agree with @ike, that's the best way, in my opinion, to go but as has been said I suppose it depends on where in the world you are and what you have at your disposal. I've used ¼" ply before now for 'portrait' style work and it's turned out fine. These 3 were done with ¼" I too use a cheap ply painted black for a backer. Or you can make a frame. Here are the three types of 'frame' I use. 1) with the 'backer' bigger than cutting, 2) Frame incorporated into cutting 3) Glued onto a large backer and then framed with another wood. Edited December 5, 2020 by Foxfold Quote
don in brooklin on Posted December 5, 2020 Report Posted December 5, 2020 (edited) If you are a newbie cutting 1/8 Baltic Birch on it own is difficult. It is easier to control the blade when cutting 1/8 material when you stack cut. You get more resistance and more control. Steve Good has some comments on cutting thin wood at https://scrollsawworkshop.blogspot.com/2020/05/mini-church-electric-tea-light-candle.html There is a video imbedded that is interesting for new and experienced. Edited December 5, 2020 by don in brooklin on GrampaJim 1 Quote
NC Scroller Posted December 5, 2020 Report Posted December 5, 2020 I agree with most of what was said. 1/8" or 1/4" Baltic Birch for the portrait. The backer can be painted or stain plywood or solid wood or other materials like colored mat board. Like Don said cutting a single piece of 1/8" or 1/4" material can be tricky. Blade size should be small like 2/0 or #1. Many people like spiral blades for portraits. If you post a picture we might be able to give you better suggests. Quote
