Thank you all for the compliments. This project is not complicated but is all about repetitive cuts. I try to cut the same pieces of the pattern at the same time so I have some memory muscle for consistent cutting. I did go through a lot of 3/0 blades because they dull fast on the oak but it does allow for sharp turns. I would have gone larger but I was limited by the wood I had available.
