Did you make it to fit the mirror or did you get the mirror last? Either way it looks lovely. Well done
Marg
Actually the pattern for the flame called for a base but I discarded the base idea and did not cut the tab that otherwise would have been in the base. Other than that change the pattern is as it was designed and just coincidentally fit the mirror which worked out well.
DW
