I'm going to try and make 3 of these for family members. One of my daughters saw this pattern and asked  if I could make 3  for her. I have not done many scroll saw fretwork patterns using BB. I will use 3 1/8" BB stacked plywood panels. What blade would you suggest for this? I'm thinking of a FD ultra reverse. Just can't decide which size. I'll be using my 21" EXCALIBUR.  All suggestions appreciated. Please don't suggest a spiral blade. I just cannot get used to those blades. Actually gave up on them a while ago.
Thanks in advance
Ben
Avatar / Picture
Edited by ben2008
  • ben2008 changed the title to What size blade?
I'd use a spiral blade number 2/0 😂
BUT, since you hate the spirals a #1 or #3 Ultra reverse might work too, 🙂 Just take it easy on the fragile areas.. Not a huge fan of a reverse tooth ( especially UR ) with fine detail fretwork.. Those reverse teeth can get grabby and bust a portion out.. I've used them on work more fragile than this.. and running the EX is smooth so you should be fine with them..
I agree with Dan, FD UR #1's will work well for this.  I just finished cutting 1/2" stacks of BB ply for a boat load of ornaments and used the FD UR #1.  It's pretty much my go-to blade for fine fretwork in all but the thickest/hardest material.  The #3 will work a little better on the letters, as there are a lot more straight lines and the #3 will offer a little better control, but the #1 would work fine for those as well.
That is a really outststanding cut.
Other than the work WELCOME the panel screames use a spiral blade.  I'd be using mostly a #1 Pegas spiral to cut it.
Probably a #3 Pegas mgt R for the Font.
For only three layers of 1/8" BB ply, almost any blade you like will work  A #1 and/or #3 is probably you best bet although I would not hesitate to use a #2/0 for some of the smaller detail areas.
Just remember, when the panel gets thicker...push slower and let the blade do the work!
Edited by FrankEV
Personally, I'd cut this as a 'fretwork' piece and put a backer on it.  I'd use a #3 blade as it's my go to blade and I can cut most things with it..
It looks awfully 'fragile' to have as a 'cut out' piece to me. JMHO
Thanks everyone for the comments, suggestion, tips etc. Looks like I'll use a #3 FD UR as my 1st choice for most of it and switch to a #1 for the smaller areas. I should be starting this later this week or early next week. Still finishing a few other projects for now.
What a great and friendly forum this is. Glad I joined not long ago.
Thanks again
Ben
Edited by ben2008
