This 30" tall giraffe was completed using a resin inlay material called Inlace Liquid Inlay.  The fretwork holes of the giraffe were cut on the scrollsaw.  A thin plywood backer board was glued to the back of the piece with construction adhesive.  The cut holes were filled with Inlace and allowed to dry.  The project was sanded and then a polyurethane finish was applied.  The finish was also applied to the natural edge of this cherry board.  There are multiple colors of this material available and I recommend the darker brown choices. This material is available at Wood Acrylic Supply on Etsy.
OPTION 2  Another method to do this project is to just reduce the wood in each spot with a rotary power tool instead of cutting the frets out with a scroll saw.  Only about 1/8"  deep is necessary.  Then fill the spots with the Inlace and proceed in the same fashion with sanding smooth and applying finish.
Edited by DickMira
Provided another method to accomplish the work.
59 minutes ago, Zoot Fenster said:
Stunning!  I have to ask, how did you cut a 30" long board on a scroll saw?
Thanks, David      Place the board horizontally across the saw table and cut with spiral saw blades.  The most physically difficult project I have ever cut was posted in Works in Progress on Nov 23  [Wildlife Montage]  Check that one out!
Edited by DickMira
