LarryEA Posted December 18, 2020 Report Posted December 18, 2020 I have a scrolling project that has detail too small for a scroll saw. Does anyone use "wood burning to enhance their work ? What burner do you recommend for very fine lines? Quote
Foxfold Posted December 18, 2020 Report Posted December 18, 2020 I have a pyrography machine 'Peter Childs' and find something like this that holds very fine tips probably your best bet. I believe one called RazorTip is popular in the USA but here's a page that may be of interest. https://craftandleisure.com/best-wood-burning-tools-pyrography-pens-buyers-guide-1020/ LarryEA 1 Quote
Roberta Moreton Posted December 19, 2020 Report Posted December 19, 2020 I have a Col wood cub. It uses wire tips. LarryEA 1 Quote
kmmcrafts Posted December 19, 2020 Report Posted December 19, 2020 I cannot remember what mine is, LOL.. Been a while since I've used it.. They no longer make the brand but the parts and pens from either colwood or razortip fits my machine.. Nothing better than a quality burners set.. I used to use one of those cheap hobby lobby type big bulky burner sets.. but these higher end machines have much better heat control and the pen isn't a huge heavy thing to hold onto.. almost like using a regular ink pen.. well worth the money if you're getting into burning.. LarryEA 1 Quote
NC Scroller Posted December 19, 2020 Report Posted December 19, 2020 Larry can you post a picture? Maybe we can offer up some ideas. I have used a wood burner on some projects but it takes a fair amount of trial and error. Quote
LarryEA Posted December 19, 2020 Author Report Posted December 19, 2020 (edited) 46 minutes ago, NC Scroller said: Larry can you post a picture? Maybe we can offer up some ideas. I have used a wood burner on some projects but it takes a fair amount of trial and error. Scott, I believe I could do the burning but I'll have my Niece who is practicing and she will do a good job. She has a steady hand, I do not. The fine lines are the ones around the windows and door. Almost all straight line burns. The problem is more a drill bit size problem. I have #68 (.0310”/.787mm) drill bits. The #68 (.0310”/.787mm) are too big. The pattern I am using is 8" x 10", still the lines are to small to drill. Almost all of the lines are a straight line burns. Edited December 19, 2020 by LarryEA Quote
NC Scroller Posted December 19, 2020 Report Posted December 19, 2020 Larry that is going to be a challenge any way you do it. If the wood is light color you might even want to try a very fine point India Ink pen and a small ruler. India Ink does not bleed like many markers do. To be safe you might to test on a piece of the same wood. Jim McDonald and LarryEA 1 1 Quote
Ctutor Posted December 19, 2020 Report Posted December 19, 2020 Larry, I use an NSK high speed (100,000 rpm) unit that is used for piercing woodturning items. I use a "dental" tip that actually burns the wood it is turning so fast. Uses about 40 PSI from my air compressor. LarryEA 1 Quote
LarryEA Posted December 19, 2020 Author Report Posted December 19, 2020 5 hours ago, NC Scroller said: Larry that is going to be a challenge any way you do it. If the wood is light color you might even want to try a very fine point India Ink pen and a small ruler. India Ink does not bleed like many markers do. To be safe you might to test on a piece of the same wood. Scott, I ordered the smallest India ink pen I could find, 0.2mm and 0.3 mm Maybe small enough. If not I can use them on other parts. NC Scroller 1 Quote
