Look for edge banding.  It is a thin wood that is used to cover the edges of plywood so the layers don't show.  It even comes with an iron on adhesive, so you don't need to clamp it in place for glue to dry.  The roll they come in is about 3" in diameter, so it should do what you want.  It is usually only available in a limited number of species (I think it may only come in birch).  But a little dye can do wonders.
Tom
My neighbor wanted to make a gutar so I made a fixtlure of the bends on the guttar He soaked it for 4 days then put it on the fixdture and let it dry for a little over a weeek and it worked out fine. He used 1/8 BBplywood  you have to have duse dthe ply crosss grained . this was 4 in. wide ply then the glue would hold . we wanted 1/16  jBBply bit cpuldn't find any around here.
IKE
