Hello Everyone
Question when looking at different model scroll saws and what they have to offer 14 inch throat length vs 18 throat length how critical is this when it comes to cutting out parts that are 14 inches or greater in length flat stock - wood sheets, would you be comprised when cutting and run into the back end of the machine, when sending your material through? Was a 14 inch saw designed  more for small intricate cutting projects ?     Any help appreciated
Hi David. Your 14" saw should be able to handle about 28" measured corner to corner. You may have to use a few additional blade entry holes to finish some cuts. If you use spiral blades you should be able to cut 28" with no troubles.
Edited by Dan
