I know we all attach backs to projects. I was using glue applied with a small glue brush. It kind of worked but if it wasn't applied just right there was some cleanup. I started using a spray, Loctite 77. Has anyone used a spray and if so, what did you use and how did you apply it, other than pushing the spray button.   Thanks in advance
Hi John. This question comes up frequently so you'll hear the best of what works from each of us. I always use wood glue if the backer is wood or some form of a wood product. If the project if framed I just spread a few drops of glue very thin to the project, just enough to hold it in place. No need for more than that. For larger, unframed projects I do the same thing only add a few extra drops in critical places. I uses weights or clamps to hold the backer in place until the glue dries. With practice you'll figure out what the right amount of glue is. I go very light with it. Never had an issue. I did this owl in 2013. It's about 3' tall and 1' wide, with picture matting material, glued with Titebond II. It's still hanging today.
I also use wood glue for the most part.. that's if they are both unfinished wood. If the backer is painted then I use WeldBond glue.
My application process is to use wax paper or a plastic trash bag.. pour a pile of glue and spread it around evenly a thin layer large enough area to be able to dip the cutout into the glue.. this gets a even coat of glue on the entire piece quickly.. Then just set it onto the backer piece and add weight or clamps etc.. I usually stack books on top for weight. This works awesome if you're gluing a larger batch of projects all at one time.. I usually am stack cutting things so typically gluing up 3-6 projects at a time.. I just use a old credit card or something to spread the glue around for good coverage for each piece I'm gluing.. Seems to be the best method I have found.. I used to just place a few drops as Dan mentioned.. But this is my go to way now..
Kevin,
What type of weldbond glue do you use and how thick is it?  I've been doing a lot of layered projects lately and have fallen in love with a glue bottle with an attached roller that I got from Rockler that works excellently with wood glue.  For painted backers I've been using Aileen's tacky glue for years with great results, but I haven't tried it in one of these bottles because it is so thick I'm afraid it wouldn't work well.  If the weldbond is thinner and will still hold onto a painted surface that might be the perfect solution.  Hand applying the Aileen's to a fretwork piece gets kind of tedious.
The weldbond glue that I had purchased was quite thick.. so much so that I had to dilute it some.. I was told that it's not normally that way and I must have gotten a old dried out bottle that had been sitting on the store shelf for some time. The bottle I have is the only one I've used.. but it's quite low and I probably going to need a new bottle soon.. I think normally it is supposed to be similar to the Aileen's tracky glue.. that is another that I have used too without issue.. The weldbond bottle says you can dilute it.. I'm not sure by how much and if it affects its holding power..
Raw wood  ot raw wood I use tight bond and for painted surfaces I use grilla glue. applied like Dan or Kevin said works well I luse books mostly to hold it in place . Tight bond sets up fastes.
IKE
I tried the 3M Super 90 Permanent Adhesive. Spray it on the back of the cutting then join the pieces together. Was quite a pain to work with, left strings over the holes and was a real pain to clean up. I used E-6000 quite a bit. Then one hot summer day, I found it would soften and seep out leaving a bit of a mess to clean up. Since I have use Titebond for most of it. If using a felt back ground I put a little extra on carefully. Have not had an issue with that. I don't think there is one "best" answer to this. Everything has it's positives and negatives.
I'm sitting in a hotel room still trying to get a house. Don't have any glue available. I seem to remember there is an expiration on glue bottles. They have a shelf life and are suppose to be pulled from shelves or shops cause they won't work as designed. RJF
Edited by teachnlearn
word change
