puzzleman Posted February 4, 2021 Report Posted February 4, 2021 Well there is packaging tape and there is packaging tape! Just bought a roll of 3M packaging tape at CVS because I had run out of my regular tape. Pathetic. I'm wondering if they provide a cheap version to CVS? The crap won't stick to my wood! Going back to my Duck brand tape! bb OCtoolguy 1 Quote
kmmcrafts Posted February 4, 2021 Report Posted February 4, 2021 I rarely use tape on wood anymore but I've had some packing tape that would hardly stick to the boxes I was packing up.. real annoying trying to get orders packed and the tape peeling off after you stick it.. I agree.. hard to beat the Duct brand stuff.. I like the Duct " Easy Start " kind as it's quiet when you unroll it.. seems heavier and stronger than most the others. Also like the Duct "Crystal Clear" but it's pretty sticky stuff.. OCtoolguy 1 Quote
teachnlearn Posted February 4, 2021 Report Posted February 4, 2021 There must be a retail brand that is garbage. I moved our family multiple times and bought cases of 3M tape and loaded it into tape guns. Moved over seas, cross country, humid storage for years, repacked old boxes and taped torn ones together. Strapped old lumber together. It survived it all. I would be scratching my head and taking ti back. RJF OCtoolguy 1 Quote
WayneMahler Posted February 4, 2021 Report Posted February 4, 2021 I've been using 3M for years and years. Neve had an issue with it. The wife brought home some off brand stuff and I doubt it would have stuck even if you used a staple gun it. I have heard a lot of good about Duck Brand. Maybe it's made by 3M ? OCtoolguy 1 Quote
jerrye Posted February 4, 2021 Report Posted February 4, 2021 (edited) Having sold tape for a living in the past, I can say that 3M is good tape, with consistent quality control, and the most expensive option available. The problem with adherence to a carton these days could be that the carton has high recycled content. Shorter fiber strands are much tougher for tape to adhere to, requiring in many cases a better tack in the adhesive. The three types of adhesive in descending order of popularity and ascending order of cost are hot melt, acrylic, and natural rubber. If you're looking to use packaging tape, hot melt will be the type with an amber tint and a tackier release, while acrylic is clear with a freer release. Natural rubber is pretty much limited to duct tape. The perception is since acrylic releases so easily that it isn't as sticky as hot melt, but that isn't true. Acrylic has a faster and stronger tack than hot melt, so a release agent is applied to the back of the carrier to enable using the tape without having to fight it to get it off of the roll. In a freezer environment, acrylic is the adhesive used as nothing else will work on cases of frozen or soon to be frozen product. Look around and see if you can find Shurtape. It's a good quality tape that will cost less than 3M...if that kind of thing matters to you. This is likely more about tape than anyone really wanted to know. Edited February 4, 2021 by jerrye NC Scroller, Badgerboy, Dan and 5 others 3 5 Quote
LarryEA Posted February 4, 2021 Report Posted February 4, 2021 Get away from tape to cover your wood. I quit using tape 15 years ago. The best product you can use is " GLAD Press N Seal " from your grocery store. It is like GLAD Saran Wrap. About 10" wide and it sticks to the wood. Peals off easy when you remove it. It is clear and you can see your wood thru it. Pull off what you need and press it on. I use a roller to take out any bubbles. Leaves no residue. Dave Monk, Dan, teachnlearn and 1 other 2 2 Quote
Bill WIlson Posted February 4, 2021 Report Posted February 4, 2021 3 hours ago, jerrye said: Having sold tape for a living in the past, I can say that 3M is good tape, with consistent quality control, and the most expensive option available. The problem with adherence to a carton these days could be that the carton has high recycled content. Shorter fiber strands are much tougher for tape to adhere to, requiring in many cases a better tack in the adhesive. The three types of adhesive in descending order of popularity and ascending order of cost are hot melt, acrylic, and natural rubber. If you're looking to use packaging tape, hot melt will be the type with an amber tint and a tackier release, while acrylic is clear with a freer release. Natural rubber is pretty much limited to duct tape. The perception is since acrylic releases so easily that it isn't as sticky as hot melt, but that isn't true. Acrylic has a faster and stronger tack than hot melt, so a release agent is applied to the back of the carrier to enable using the tape without having to fight it to get it off of the roll. In a freezer environment, acrylic is the adhesive used as nothing else will work on cases of frozen or soon to be frozen product. Look around and see if you can find Shurtape. It's a good quality tape that will cost less than 3M...if that kind of thing matters to you. This is likely more about tape than anyone really wanted to know. I actually found it interesting. Thanks for the insight! OCtoolguy and jerrye 2 Quote
teachnlearn Posted February 4, 2021 Report Posted February 4, 2021 3 hours ago, LarryEA said: Get away from tape to cover your wood. I quit using tape 15 years ago. The best product you can use is " GLAD Press N Seal " from your grocery store. It is like GLAD Saran Wrap. About 10" wide and it sticks to the wood. Peals off easy when you remove it. It is clear and you can see your wood thru it. Pull off what you need and press it on. I use a roller to take out any bubbles. Leaves no residue. Then the question follows, does the wood stay fresh and tasty? RJF kmmcrafts, Dan and OCtoolguy 3 Quote
OCtoolguy Posted February 4, 2021 Report Posted February 4, 2021 Believe it or not, I bought a roll of cellophane tape at H/F for $1 and it seems to work well. I'm not any kind of expert on tape but whatever sticks long enough to get the job done is what I want. I also like it be be as thin as possible. Quote
Roberta Moreton Posted February 4, 2021 Report Posted February 4, 2021 I use the duck brand when making compound cut pieces. OCtoolguy 1 Quote
WayneMahler Posted February 4, 2021 Report Posted February 4, 2021 10 hours ago, jerrye said: Look around and see if you can find Shurtape. It's a good quality tape that will cost less than 3M...if that kind of thing matters to you. This is likely more about tape than anyone really wanted to know. +jerrye Thanks for the education on tape. Any day we can learn something ( and remember it ) is a good day. Gee I hope he don't plan on a pop quiz over this . OCtoolguy, teachnlearn, jerrye and 3 others 3 3 Quote
Sparkey Posted February 6, 2021 Report Posted February 6, 2021 I quit using packaging tape and have been using blue painters tape. The blue painters tape hold my stack cutting together great and comes off easy after. kmmcrafts and danny 2 Quote
jerrye Posted February 7, 2021 Report Posted February 7, 2021 (edited) On 2/4/2021 at 11:19 AM, Bill WIlson said: I actually found it interesting. Thanks for the insight! I've had much said about what comes out of my mind over the years, but interesting and insight are rarely heard in the comments.... On 2/4/2021 at 6:26 PM, WayneMahler said: +jerrye Thanks for the education on tape. Any day we can learn something ( and remember it ) is a good day. Gee I hope he don't plan on a pop quiz over this . Learn? Yeah. Remember? Nah, unless it's something that you've relied on for a living over a decade or so...which enables scoring fairly well on a pop quiz. There is a lot more where that came from, but is it useful? Edited February 7, 2021 by jerrye WayneMahler 1 Quote
Rolf Posted February 7, 2021 Report Posted February 7, 2021 (edited) I never put clear tape directly to the wood. It is a pain to get off and very easy to miss a sliver during removal that will show up when you are putting on a finish. Painters tape for very small projects or removable Contact brand shelf liner (clear) for the rest of the projects. except on Intarsia there the pattern goes directly on the wood since it gets sanded off during shaping anyway . Edited February 9, 2021 by Rolf WayneMahler 1 Quote
puzzleman Posted February 7, 2021 Author Report Posted February 7, 2021 On 2/3/2021 at 8:38 PM, puzzleman said: Well there is packaging tape and there is packaging tape! Just bought a roll of 3M packaging tape at CVS because I had run out of my regular tape. Pathetic. I'm wondering if they provide a cheap version to CVS? The crap won't stick to my wood! Going back to my Duck brand tape! bb Duck brand packaging tape arrived yesterday. 2 days from Amazon. How do you spell relief? Duck Brand, Duck Brand, Duck Brand!!!! I wish the USPS would treat my Priority Mail packages like they do Amazon's packages! danny 1 Quote
Phantom Scroller Posted February 9, 2021 Report Posted February 9, 2021 I buy 2" tape sellotape three rolls for a pound in Poundland UK always worked for me. I use repositional spray glue on the patterns stick them to the wood then tape on top when it's done peels right off. Works great, I guess it's what works out for you best that matters. Quote
