4 minutes ago, Rockytime said:
I purchased a Brother B&W laser printer. I usually take my patterns to Office Max and have them printed in red. I used up the sample toner cartridge. I ordered magenta toner and refilled the black cartridge with it. The instructions for doing the refill were kind of bogus so I just drilled a 1/4" hole in top of the cartridge and filled it that way. I put a piece of tape over the hole. I think after the second refilling it should work well. It is impossible to get the black toner completely out of the cartridge so the images are sharp but a muddy red. This should clear up. I have a very nice ink jet printer if I need B&W. I find red patterns easier to scroll because of the contrast between the pattern and the blade. Also when drilling I can see what has not been drilled. Holes and black pattern look pretty much alike and I find myself occasionally trying to drill something that has already been cut.
Great idea Les. Glad it worked for you.
