Just bought a Hegner Multimax 18, year 1990.  I disassembled it and am giving it a good cleaning and fresh oil.  I hit a glitch in trying to reattach the connector arm to the flywheel.  There are two threads, one inner and the other outer.  I did not notice that when I removed the connector.  Anybody know which is the correct thread to use?
Thank you!
23 minutes ago, nrscroller said:
HI
This is interesting, I guess I knew about that from the book, so what do you gain by channging to the inner hookup, I do a lot of 1/8 inch bb plywood stuff
Bill
A much kinder, gentler saw.
The outer hole gives a longer stroke versus a shorter stroke from the inner hole.  I'v tried the inner hole to reduce vibrations before I built a new stand and it didn't really help.  I'm not sure what you would need a short stroke for; maybe a new scroller would use it to slow the cutting rate.
