Popular Post FrankEV Posted March 11, 2021 Popular Post Report Posted March 11, 2021 I thought I would post this group of cuts so you did not need to read the same thing over and over. These are all patterns converted from ZM Creations Illustrations. All of these portraits were completed in a similar way with a smaller sized 5/32” thick solid core plywood cut panel affixed to a larger 1/4” thick BB plywood backer. Each backer was sealed, then coated with the white Krylon Spray Gesso (Acrylic Paint primer) and the 1” borders were painted in various rattle can Krylon Fusion All-In-One Matt colors. The areas under the open cut areas were colored with Acrylic Art Paints, using the original illustrations as a guide. As usual, each panel was protected with multiple coats of clear gloss spray Lacquer. Each cut, being quite simple, was completed in less than one 3-4 hour session. That was a one per day but painting and framing added many hours to each. Cuttings were completed with Pegas #1 MGT R and/or #2/0 spiral blades. Each panel was set loose in a simple 1 3/4” wide Poplar frame that I applied a coat of pre-stain conditioner followed by a coat of Minwax Brazilian Gel Stain and protected with coat of Spray satin Polyurethane. Peacock: 9” x 10 ¼” Maple Toucan: 9”X12” Maple Birds3: 9” x 10 3/4” Maple Birds4: 11 1/2” x 9” Birch Bird5: 9” x 9” Birch Bird6: 6” x 11 3/4” Maple The following .zipx file contains all of these patterns including the Simple Eagle. Birds - ZM Creations.zipx Hope you enjoy! Jim Blume, meflick, Frank Pellow and 16 others 17 2 Quote
Scrappile Posted March 11, 2021 Report Posted March 11, 2021 I really like how you do your pictures... Very pleasant to look at. Thanks for the down load of the patterns... FrankEV 1 Quote
Woodrush Posted March 11, 2021 Report Posted March 11, 2021 3 hours ago, FrankEV said: I thought I would post this group of cuts so you did not need to read the same thing over and over. These are all patterns converted from ZM Creations Illustrations. All of these portraits were completed in a similar way with a smaller sized 5/32” thick solid core plywood cut panel affixed to a larger 1/4” thick BB plywood backer. Each backer was sealed, then coated with the white Krylon Spray Gesso (Acrylic Paint primer) and the 1” borders were painted in various rattle can Krylon Fusion All-In-One Matt colors. The areas under the open cut areas were colored with Acrylic Art Paints, using the original illustrations as a guide. As usual, each panel was protected with multiple coats of clear gloss spray Lacquer. Each cut, being quite simple, was completed in less than one 3-4 hour session. That was a one per day but painting and framing added many hours to each. Cuttings were completed with Pegas #1 MGT R and/or #2/0 spiral blades. Each panel was set loose in a simple 1 3/4” wide Poplar frame that I applied a coat of pre-stain conditioner followed by a coat of Minwax Brazilian Gel Stain and protected with coat of Spray satin Polyurethane. Peacock: 9” x 10 ¼” Maple Toucan: 9”X12” Maple Birds3: 9” x 10 3/4” Maple Birds4: 11 1/2” x 9” Birch Bird5: 9” x 9” Birch Bird6: 6” x 11 3/4” Maple The following .zipx file contains all of these patterns including the Simple Eagle. Birds - ZM Creations.zipx 182.97 kB · 5 downloads Hope you enjoy! Great looking work . The colours pop FrankEV 1 Quote
munzieb Posted March 11, 2021 Report Posted March 11, 2021 The background painting match is perfect. The contrasting matting makes them pop and I really like the picture frames you did. Professional and artistic work. FrankEV 1 Quote
wombatie Posted March 12, 2021 Report Posted March 12, 2021 They are a lovely bunch, very colorful too. You did an excellent job on the painting. Marg FrankEV 1 Quote
Phantom Scroller Posted March 12, 2021 Report Posted March 12, 2021 Wow! from me they look great . Roly FrankEV 1 Quote
heppnerguy Posted March 13, 2021 Report Posted March 13, 2021 On 3/11/2021 at 5:59 AM, FrankEV said: I thought I would post this group of cuts so you did not need to read the same thing over and over. These are all patterns converted from ZM Creations Illustrations. All of these portraits were completed in a similar way with a smaller sized 5/32” thick solid core plywood cut panel affixed to a larger 1/4” thick BB plywood backer. Each backer was sealed, then coated with the white Krylon Spray Gesso (Acrylic Paint primer) and the 1” borders were painted in various rattle can Krylon Fusion All-In-One Matt colors. The areas under the open cut areas were colored with Acrylic Art Paints, using the original illustrations as a guide. As usual, each panel was protected with multiple coats of clear gloss spray Lacquer. Each cut, being quite simple, was completed in less than one 3-4 hour session. That was a one per day but painting and framing added many hours to each. Cuttings were completed with Pegas #1 MGT R and/or #2/0 spiral blades. Each panel was set loose in a simple 1 3/4” wide Poplar frame that I applied a coat of pre-stain conditioner followed by a coat of Minwax Brazilian Gel Stain and protected with coat of Spray satin Polyurethane. Peacock: 9” x 10 ¼” Maple Toucan: 9”X12” Maple Birds3: 9” x 10 3/4” Maple Birds4: 11 1/2” x 9” Birch Bird5: 9” x 9” Birch Bird6: 6” x 11 3/4” Maple The following .zipx file contains all of these patterns including the Simple Eagle. Birds - ZM Creations.zipx 182.97 kB · 12 downloads Hope you enjoy! I really like these projects and your framing is fabulous also. I especially enjoyed the different choices for your matt colors, it shows how important the matt can be in a finished project. Thanks for posting I enjoyed viewing them all Dick heppnerguy FrankEV 1 Quote
Scrappile Posted March 17, 2021 Report Posted March 17, 2021 Ahhh, can anyone tell me how to unzip a "zipx" file...on a Mac Mini? I am having no success. Quote
FrankEV Posted March 17, 2021 Author Report Posted March 17, 2021 9 minutes ago, Scrappile said: Ahhh, can anyone tell me how to unzip a "zipx" file...on a Mac Mini? I am having no success. Have no idea, but will send you each of the .pdf files in a PM. Scrappile 1 Quote
