Popular Post Denny Knappen Posted March 23, 2021 Popular Post Report Posted March 23, 2021 A project finished Monday. This is a Steve Good pattern. I used 1/4" solid Walnut and backed with 3/8" Baltic Birch plywood. I used 3/8" so that it would hold the hanger without going through the wood. Cut on the Pegas Scroll Saw using #1R MGT blades on all interior cuts and #3R on the exterior cuts. The finish is one coat spray Shellac as a sanding sealer. Then two coats MinWax Lacquer Clear Satin, sanding in between coats. I should have used 1/8" so that the white would show through the Walnut. 150 holes. Comments welcome. TexasDIY, Fish, jollyred and 16 others 19 Quote
heppnerguy Posted March 23, 2021 Report Posted March 23, 2021 30 minutes ago, Denny Knappen said: A project finished Monday. This is a Steve Good pattern. I used 1/4" solid Walnut and backed with 3/8" Baltic Birch plywood. I used 3/8" so that it would hold the hanger without going through the wood. Cut on the Pegas Scroll Saw using #1R MGT blades on all interior cuts and #3R on the exterior cuts. The finish is one coat spray Shellac as a sanding sealer. Then two coats MinWax Lacquer Clear Satin, sanding in between coats. I should have used 1/8" so that the white would show through the Walnut. 150 holes. Comments welcome. I saw this one on Steve's page. I thought it would make an interesting project. You proved my thoughts to be correct. Looking good Dick heppnerguy Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 16 minutes ago, heppnerguy said: I saw this one on Steve's page. I thought it would make an interesting project. You proved my thoughts to be correct. Looking good Dick heppnerguy Thanks Dick. I like how it turned out, but there were 150 holes. Some holes real small. heppnerguy 1 Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 1 hour ago, rjR said: Very nicely done. Thanks RJ. Quote
FrankEV Posted March 23, 2021 Report Posted March 23, 2021 It is a great piece. Very well done. I concur, thiner cut panel would have been visualy better. I have found that to be a truism for most fretcut projects where the background needs to show through. Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 1 minute ago, FrankEV said: It is a great piece. Very well done. I concur, thiner cut panel would have been visualy better. I have found that to be a truism for most fretcut projects where the background needs to show through. Thanks Frank. I didn't have a piece of 1/8" Walnut. I should have stained Baltic Birch plywood. I still like the look of the Walnut. Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 3 minutes ago, lawson56 said: An Excellent job!! Thanks Bobby. Stop by ArtCrafters sometime. Quote
lawson56 Posted March 23, 2021 Report Posted March 23, 2021 If I,m ever in Dayton, I drop by and say Howdy. Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 9 minutes ago, lawson56 said: If I,m ever in Dayton, I drop by and say Howdy. You can even play with the Pegas Scroll Saw amazingkevin 1 Quote
Denny Knappen Posted March 23, 2021 Author Report Posted March 23, 2021 14 minutes ago, Joe W. said: Comments? Only one - Beautiful! Thanks Joe. Quote
FrankEV Posted March 24, 2021 Report Posted March 24, 2021 3 hours ago, Denny Knappen said: Thanks Frank. I didn't have a piece of 1/8" Walnut. I should have stained Baltic Birch plywood. I still like the look of the Walnut. I often use the Walnut 5/32" purebond Solid Core ply I get fron HD. Add some Walnut stain and it even look better. Finishes beautifuly. Quote
scrollerpete Posted March 24, 2021 Report Posted March 24, 2021 Another masterpiece Denny, stay safe Quote
Denny Knappen Posted March 24, 2021 Author Report Posted March 24, 2021 13 hours ago, Scrappile said: Great job Denny! Thanks Paul. A fun project. Quote
Denny Knappen Posted March 24, 2021 Author Report Posted March 24, 2021 5 hours ago, Tomanydogs said: Very pretty. Thanks Irene. Quote
Denny Knappen Posted March 24, 2021 Author Report Posted March 24, 2021 2 hours ago, dgman said: Looks good Denny! Thanks Dan. Any projects on the new Saw? Quote
Denny Knappen Posted March 24, 2021 Author Report Posted March 24, 2021 1 hour ago, daveww1 said: terrific job, it's beautiful Thanks Dave Quote
Denny Knappen Posted March 24, 2021 Author Report Posted March 24, 2021 5 minutes ago, scrollerpete said: Another masterpiece Denny, stay safe Thanks Pete. You stay safe too. Quote
Frank Pellow Posted March 24, 2021 Report Posted March 24, 2021 Well done! I've been thinking of doing this pattern for some time. The way that you have utilized the pattern is an inspiration and I think that I I have some Walnut somewhere that will be appropriate. The only problem will be in finding that Walnut. Quote
