Welcome to the Village Jerry! A scroll saw is a great tool for cutting 3/4” pine! When you say you are having trouble making good clean cuts, are you using a scroll saw or a jig saw? Using a scroll saw with the right blade you should get a very clean cut. You will never get a clean cut using a jigsaw. Using a scroll saw, you are limited to the the length of the of the arms of the saw. So, with a 16” saw you are limited to 32” if you cut from two directions. If you have a 21” saw, you can cut 42” from two directions. You can get unlimited capacity if you use spiral blades, but you won’t get as smooth a cut.
So, tell us what you have and what you are using so we can help you better.
