tgiro Posted April 24, 2021 Report Posted April 24, 2021 As I'm constantly making "Bowls-from-boards" I'm always having to drill holes at a 45° angle. I've made a couple of jigs,with limited success, but they are far from perfect. I have seen jigs & guides on the web (some thing like this - https://www.amazon.com/ANGLE-DRILL-GUIDE-increments-settings/dp/B006ZBCS1M ), but I wonder if they are more gadgets that work sometimes. Has anyone used anything like this, and, if so what are your recommendations? Or, is there a made jig that you have used with good success? I have some angle jigs that work very well, but, when you're drilling 35° or more, they fail. Any good recommendations? OCtoolguy 1 Quote
jerry1939 Posted April 24, 2021 Report Posted April 24, 2021 Will this help? Super Easy Way to Drill Angled Holes! - YouTube Dan and OCtoolguy 1 1 Quote
preprius Posted April 25, 2021 Report Posted April 25, 2021 my hand drill does not hold #60 drill. But the video was good for bigger drill sizes. OCtoolguy 1 Quote
kywoodmaster Posted April 25, 2021 Report Posted April 25, 2021 I have one of the drill guides that works pretty well. I don't think it will hold the small bit . OCtoolguy 1 Quote
Norm Fengstad Posted April 25, 2021 Report Posted April 25, 2021 thanks for another good idea OCtoolguy 1 Quote
barb.j.enders Posted April 25, 2021 Report Posted April 25, 2021 I recently purchased the plunge router base from StewMac. They had a sale on - two for one. It actually ended up being a little cheaper than buying just the plunge router base. The second piece was their tilting base. I haven't tried it yet. https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/routers-and-bits/stewmac-tilt-router-base.html OCtoolguy 1 Quote
Wilson142 Posted April 25, 2021 Report Posted April 25, 2021 Seems to me the deflection of the small diameter bit could be as much a problem as a good jig. Other than using very sharp bits, controlled feed speed and consistency in wood density, I don't really see the problem. LOL I'll be interested in how you finally solve your problem. OCtoolguy and Dave Monk 2 Quote
WayneMahler Posted April 25, 2021 Report Posted April 25, 2021 I've seen plans somewhere for a jig that is hinged and holds the angled setting by tightening a wing nut or threaded knob. I think the used a friction hinge for the angle stop and regular butt hinges for the joint. Set the desired angle , mark you spot, center punch it to keep the bit from walking, drill the hole. If it gets to work out or used up, you only have to make the top to replace. Hope this helps. OCtoolguy 1 Quote
NC Scroller Posted April 25, 2021 Report Posted April 25, 2021 Can you use a drill press? Put a 45 degree, or whatever angle, wedge under your piece of wood and then drill straight down. Fish and OCtoolguy 2 Quote
preprius Posted April 25, 2021 Report Posted April 25, 2021 What we need is an accessory that clamps to the upper arm of the scroll saw. This way we can reuse the same tilt mechanism. We dont have to set 2 tools for same angle. For the Hawk the upper arm already has a spring mechanism to have the drill motor act as plunge spring. So a sturdy clamp for small drill motor would simpify the accessory. The upper arm already has side to side sturdiness built in also. The depth of drill will need to adjustable but the upper arm already moves the maximum drill depth. Can a seyco drill motor be adapted to this kind of clamping accessory? For other types of saw upper arms maybe the spring plung will be needed. OCtoolguy 1 Quote
oldhudson Posted April 25, 2021 Report Posted April 25, 2021 (edited) What Wayne described.... Rockler has plans for a tilting base to be added to a drill press. https://www.rockler.com/tilting-table-for-the-drill-press-plan Here's a simple drill guide that might be what you need https://www.amazon.com/Muzata-Installation-Horizontal-Drilling-Template/dp/B083Q8K2N5 You didn't say what size holes you needed. But when I work on tables and make those corner blocks that go between aprons and hold the legs I find forstner bits work much better drilling angled holes than your other types of bits. Edited April 25, 2021 by oldhudson OCtoolguy 1 Quote
OCtoolguy Posted April 25, 2021 Report Posted April 25, 2021 I've only done a couple of things where I had my table tilted or needed an angled hole. What I did was just cut a small piece of 1 x a couple of inches long and then cut it at the angle I needed. I clearly marked it at what angle it is and put it aside for the next time I needed that angle. Quote
merlin Posted April 25, 2021 Report Posted April 25, 2021 This any good to yah...https://www.woodworkersjournal.com/wp-content/uploads/WJ095-Drill-Press-Table.pdf Norm Fengstad and OCtoolguy 1 1 Quote
Rockytime Posted April 26, 2021 Report Posted April 26, 2021 12 hours ago, barb.j.enders said: I recently purchased the plunge router base from StewMac. They had a sale on - two for one. It actually ended up being a little cheaper than buying just the plunge router base. The second piece was their tilting base. I haven't tried it yet. https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/routers-and-bits/stewmac-tilt-router-base.html StewMac makes the finest tools! You will love it. This is what I use. One hand operation and deadly accurate. barb.j.enders 1 Quote
tgiro Posted April 26, 2021 Author Report Posted April 26, 2021 Let me clarify a bit. I have to use small bits I trey to use sizes between #50 - #57. The very largest I use is a 1/16" - sometimes a 1mm or 2mm. These bits are very short. The drill press chuck is big enough that it hits the wood before the hole is complete, when using the smaller bits. I have tried the jig from the video Jerry suggested - Thank you, Jerry. The issue with that one is that it covers the spot where I'm supposed to drill and the thickness of the jig prevented to small bits from completing the hole. Here is a couple of pictures of my current drill press jig, which works mostly. It's OK with a 1/16th" bit or the 1mm & 2mm. The smaller bits don't complete the hole before the chuck hits the wood. I have tried to find a smaller chuck, that I could clamp into the DP chuck, but I can't find on that holds drill bits less than 1/16th". OCtoolguy 1 Quote
Rockytime Posted April 26, 2021 Report Posted April 26, 2021 2 minutes ago, tgiro said: Let me clarify a bit. I have to use small bits I trey to use sizes between #50 - #57. The very largest I use is a 1/16" - sometimes a 1mm or 2mm. These bits are very short. The drill press chuck is big enough that it hits the wood before the hole is complete, when using the smaller bits. I have tried the jig from the video Jerry suggested - Thank you, Jerry. The issue with that one is that it covers the spot where I'm supposed to drill and the thickness of the jig prevented to small bits from completing the hole. Here is a couple of pictures of my current drill press jig, which works mostly. It's OK with a 1/16th" bit or the 1mm & 2mm. The smaller bits don't complete the hole before the chuck hits the wood. I have tried to find a smaller chuck, that I could clamp into the DP chuck, but I can't find on that holds drill bits less than 1/16th". Just purchase a Dremel chuck and chuck it up in the big drill chuck. I can hold #80 bits in it. Have done it for years. OCtoolguy 1 Quote
preprius Posted April 26, 2021 Report Posted April 26, 2021 I decided to make this my next project. I ordered stuff to do it today. We will send pictures when I get it going. Quote
OCtoolguy Posted April 26, 2021 Report Posted April 26, 2021 (edited) From your picture, it appears that you should be able to lower your d/p table so that your workpiece is closer to the top of the jig and give you the most depth of drilling. Not sure what thickness you are working with but I'm assuming 3/4" if it's for bowls. Those tiny bits are really short but I would think if you could lower the table or raise the project wood up higher, it would allow you to drill deeper. Edited April 30, 2021 by octoolguy Quote
Mikes shed Posted April 26, 2021 Report Posted April 26, 2021 On 4/25/2021 at 9:00 AM, tgiro said: As I'm constantly making "Bowls-from-boards" I'm always having to drill holes at a 45° angle. I've made a couple of jigs,with limited success, but they are far from perfect. I have seen jigs & guides on the web (some thing like this - https://www.amazon.com/ANGLE-DRILL-GUIDE-increments-settings/dp/B006ZBCS1M ), but I wonder if they are more gadgets that work sometimes. Has anyone used anything like this, and, if so what are your recommendations? Or, is there a made jig that you have used with good success? I have some angle jigs that work very well, but, when you're drilling 35° or more, they fail. Any good recommendations? Hi my friend and myself were discussing this very topic last week and what we do is to use a drill press that has a tilting table. we set the table to the required degree and then drill to our hearts content no problems all the holes are the same angle. OCtoolguy 1 Quote
preprius Posted April 29, 2021 Report Posted April 29, 2021 On 4/25/2021 at 10:09 AM, preprius said: What we need is an accessory that clamps to the upper arm of the scroll saw. This way we can reuse the same tilt mechanism. We dont have to set 2 tools for same angle. For the Hawk the upper arm already has a spring mechanism to have the drill motor act as plunge spring. So a sturdy clamp for small drill motor would simpify the accessory. The upper arm already has side to side sturdiness built in also. The depth of drill will need to adjustable but the upper arm already moves the maximum drill depth. Can a seyco drill motor be adapted to this kind of clamping accessory? For other types of saw upper arms maybe the spring plung will be needed. FAILED attempt #1. Clamp drill motor to upper arm. Use upper arm to act like plunging mechanism. That is just push arm down to drill. Failure was my clamp structure was not 90deg. drill won't go straight even it I did have 90deg. Next attempt will be to use the fixed bar (on the other side) and add plunging mechanism. Change drilling motor to smaller device. OCtoolguy 1 Quote
CharleyL Posted May 2, 2021 Report Posted May 2, 2021 The drill guide that you originally posted will not do what you need, nor will the 2 or 3 others on the market of similar design. A small drill press with a special smaller drill chuck in the larger chuck will hold the very small sizes of drill bits. Tilting the drill press table to the desired angle and building a wooden stop to hold your work piece in the needed position on the drill press table will be needed. Then you will have the difficulty of keeping the small drill bit from walking off position as you attempt to start it into the work. Only very slow feeding and care will get your drilled hole in the correct place without the drill bit walking, unless you buy a very small center drill to use first to make a starting hole for the drill bit to give the drill bit an accurate location to begin drilling the desired hole, will completely avoid the drill bit walking problem. It's easy to drill a hole at 90 deg to your work surface, but considerably more difficult to drill a hole when the work piece must be drilled at an angle. Centering drill bits can be purchased in many sizes and lengths from industrial suppliers like Grainger, Johnstone Supply, McMaster Supply, W. T. Tool, Etc. They will have the smaller drill chucks to adapt your drill press chuck to the smaller drill bits too. Charley OCtoolguy 1 Quote
Scrappile Posted May 2, 2021 Report Posted May 2, 2021 When I drill very small holes and need them to start in a certain spot, I just use a good size pin or my little ice pick to make a start hole. And if you have to use a second chuck to hold your small bits.... get a good one,, don't go real cheap... I have yet to find one that didn't wobble. One of the things I like most about my Jet drill press,,, the chuck closes all the way... It will hold the tiny bits. OCtoolguy 1 Quote
Seeseasaw Posted May 2, 2021 Report Posted May 2, 2021 Could you glue a cheap bubble level to the end of your drill and have it set for 45 degrees? OCtoolguy 1 Quote
Roberta Moreton Posted May 4, 2021 Report Posted May 4, 2021 I have a Dremel Workstation. Why wouldn’t that work? It allows me to tilt the dremel. Quote
