Fret Box
munzieb
10 hours ago, Rockytime said:
WOW, that's a gorgeous box. I'm totally impressed with the mitered corners. I don't know what tool or saw you use to that but dang, it looks good.
Easier than you think. If it was 1/2" or larger material, I would have to cut the miters on a table saw or router but since it's only 1/4" I use my belt/disc sander. It has a plate on the disc side where the angle can be adjusted and I set it to 30 degrees. It has a sliding miter on the plate and I feed the piece against the disc until I get a sharp edge. I just make sure all the pieces are the same length. I did the same with all the small pieces I used for stops on the top.
  • 4 weeks later...
