Hi Frank. I love the photos and the way you've tried to explain it all. As one who has used a mitre saw only a few times for cutting sheets down to size but my blade tears the back side of my ply. The youtube video blade has huge teeth whereas the saw in your photo has very similar teeth to mine.
Couple of questions;
To Frank;
Top 2 photos; - Do you have anything attached to your jig that fits in those grooves to keep it all straight as you saw?
Bottom 3 photos;- I can see how you're clamping that sheet between the  two 3/4in sheets of ply but how are you accessing that sheet when its held between the two outer sheets. Are you working from underneath?
To everybody; My saw does not tear 'real' wood or lumbar but it is not great cutting BBP. What is the best blade for BBP?
thanks
Bob
14 hours ago, savethebeer said:
To Frank;
Sled:  I used aluminum T-track runners attached to the bottom of the sled in both tracks of the table saw.  (The left on is visible in the second photo) You can get them on-line.   Hardwood runners would also work as shown in the video. The aluminum T-tracks were the hardest to get perfectly aligned parelel to the blade with no "slop".
I use a thin 80 carbide tooth blade intended for fine cutting.  I'm not using the saw for more general construction cutting.  Most of the saw use is in making my panels and frames, so I find this blade to work the best for me.  Hardly ever cut any wood thicker than 3/4".
Clamp:  Not quite sure what you are asking.  To clamp a panel my procedure is:
  1. After removing the top of the clamp I lay the backer on the lower portion of the clamp,
  2. I apply a nice thin uniform coatimg of Titebond Glue to the cut panel with a roller,
  3. I lay the cut panel on top of the backer, making sure it is all lined up,
  4. Being very careful, I slide the top of the clamp down the bolts to lay on top of the layered panel.  The bolts prevent any side to side movement.
  5. The weight of the top helps hold the panel in place preventing any sliding of the panels while I spin the wing nuts on, to apply a uniform pressure across the panel.
  6. I will leave the clamp in place for at least an hour, but usually two or more hours, before removing the clamp.
Hope this answers you questions.
Thanks Frank. I misread what you wrote about sticking the backer to the piece, I was reading it as a continuation of your first section to do with sawing.
My table saw is small and does not have those guide grooves but I will look at a finer blade.
Bob
  • 2 weeks later...
I'm building a frame jig similar to yours. Got the base cut and the pieces ordered have all come in. Hope to get back to it in the next week. Also building a cross cut sled. It will be a little larger that the one I gave to the guy that bought my Kobalt saw. I'm using nylon runners this time, the wood ones on the last sled were always changing size. If I remember I'll put up a picture when I get it finished.
I  built a panel cutting sled, but I find just using my tape measure and the table saw rip fence,I can cut my panels more accurately than with the sled.
A cross cut sled is great for accurate/square cross cuts for doing big wood projects.  For doing frames and the occasional need for some boards trimmed to length, my precision aftermarket T-slot tee with a wide board attached works just fine.
