padraig Posted May 8, 2021 Report Posted May 8, 2021 I just joined yesterday and have a couple of questions which I posted on the intro forum. These are pics that go with the questions if anyone can help. Supplementary question is what's that little attachment on the right front corner of the table for? And any idea where I might get a user manual. Clarke only hold 16 inch models Thanks. Quote
kmmcrafts Posted May 8, 2021 Report Posted May 8, 2021 Welcome to the Village! I don't know anything about this brand of saw, don't think I've ever seen one in person but have seen images online from time to time. I'm guessing this saw has removable blade holders and that piece on the right corner in your third picture looks to me like a fixture to hold that blade holder while you tighten the screw to hold the blade. So yeah it's a blade holders holder to tighten the blade down.. danny 1 Quote
Wichman Posted May 8, 2021 Report Posted May 8, 2021 The Clarke website is here: https://www.clarkeservice.co.uk/product_manuals/woodworker_scroll_saws.shtml I didn't see your saw listed, but there is a way to have them search their archives to see if they have a copy. WayneMahler 1 Quote
padraig Posted May 8, 2021 Author Report Posted May 8, 2021 Ok thanks for that I change the blade by taking off the tension then applying tension once its seated. Cant see any other way and yes I've been on there. Basically there is little difference between mine and those listed apart from I have a fixed speed and ab 18 inch throat, my table is cast iron and I cant take pinless blades although there is an adaptor for that I believe. Also I found another fret blade in my shed with 5 inch dimensions and it works so looks like blade length isn't critical. Both blades are pretty blunt I think. I'll order a few and see how it goes. I've got a bit of foam rubber to bolt it to a little bench so that will probably make a difference. Now all I need is inspiration Quote
