Rockytime Posted May 18, 2021 Report Posted May 18, 2021 I recently purchased a set of small rasps about 5 or 6 inches long about the size of pattern files. I have many small files but they are really too fine to remove wood particles. These are unbelievably coarse and are not very suitable. Of course the were real cheap and chinese. Any have a suggestion for me? OCtoolguy and FrankEV 2 Quote
FrankEV Posted May 18, 2021 Report Posted May 18, 2021 For dressing up fretwork and fontwork, I found that a good set of rotary carving tools that fit the Dremel Tool are the most handy. I've tried small files, sanding sicks and more, but none fit into this tight places that need some help. The rotary carving tools come in a veriety of shapes and the very small slightly tapered bit gets into all those very small tight places. The larger cylindar shaped bit is great for straightening those long straigt or long smooth curved cuts where the saw blade may have gone a little astray. So, whatever you planned to use the rasps for, the carving bits would work better and quicker. Rockytime and OCtoolguy 2 Quote
Rockytime Posted May 18, 2021 Author Report Posted May 18, 2021 Thanks Frank. The burrs will arrive Thursday! OCtoolguy and FrankEV 1 1 Quote
ike Posted May 18, 2021 Report Posted May 18, 2021 I don't have too many probllems with burrs after using a rotory sander . on some pieces dt sanding mop will also work, but not on fine pieces after sawing. IKE OCtoolguy 1 Quote
BadBob Posted May 18, 2021 Report Posted May 18, 2021 What burrs are you using? Post a link please if you have one. OCtoolguy 1 Quote
JAC1961 Posted May 18, 2021 Report Posted May 18, 2021 I bought a set of 10-Piece Mini Diamond Needle File Set (6" Total Length 150 Grit Diamond File) by Kalim from Amazon last fall and really like them. Don't seem to clog and are the right coarseness for me. Also bought a set for my daughter when she started scrolling. OCtoolguy and danny 1 1 Quote
Badgerboy Posted May 18, 2021 Report Posted May 18, 2021 Rocky, while I am not a fan of Lowes in any way I did find this set there over a year ago and for me it is perfect. Was not expensive, you may want to check it out. OCtoolguy 1 Quote
Rockytime Posted May 18, 2021 Author Report Posted May 18, 2021 On 5/18/2021 at 11:09 AM, BadBob said: What burrs are you using? Post a link please if you have one. Expand I just searched "Carbide Burs for Dremel". A thousand wil come up. I bought the first one that came up. Most are al the same with a 1/8" shank. I think I just paid about $10. Probably an assortment of a dozen tiny burrs. Being old and computer deficient I'm not sure how to post a link. Probably to old to learn also. OCtoolguy 1 Quote
Rockytime Posted May 18, 2021 Author Report Posted May 18, 2021 On 5/18/2021 at 4:26 PM, Badgerboy said: Rocky, while I am not a fan of Lowes in any way I did find this set there over a year ago and for me it is perfect. Was not expensive, you may want to check it out. Expand I sincerely thank you for the suggestion. Having had a clock repair business for over 40 years I have well over a hundred files of every size and description including sets of pattern, riffler, diamond, Barrett, bastard, mill, slotting, safe edge and more. I inherited many more from a gunsmith friend. I find what works on metal does not work very well on wood for me. I use small pattern files, cosmetic nail sanding sticks, rolled up sand paper and whatnot. I use a Dremel with brass and fiber bristles, sanding mop and 3M buffs. I have micro torches which I have not used as I cut 1/8" pre-finished BB and the finish will melt. The micro burrs will arrive Thursday. I'll see how satisfied I will be. OCtoolguy 1 Quote
BadBob Posted May 18, 2021 Report Posted May 18, 2021 I found these to be quite handy for the work I do with wood. I have never used them for anything else. Needle File Set, 10 Pc. OCtoolguy 1 Quote
Scrappile Posted May 18, 2021 Report Posted May 18, 2021 I have this HF set,,, Thought I would not use them much but I have,,,, Thought they would not last but they have... https://www.harborfreight.com/hand-tools/tool-sets/chisel-file-sets/12-piece-precision-needle-file-set-4614.html OCtoolguy 1 Quote
ben2008 Posted May 19, 2021 Report Posted May 19, 2021 (edited) I recently bought this from Micro Mark. It is one cool little mini power sander. It gets into a lot of places that you just can't reach by hand and saves a lot of time. I found in very useful for fretwork. Especially for the long wavy cuts you get sometimes. Check it out. It is not a toy. https://www.micromark.com/MicroLux-Micro-Sander Edited May 19, 2021 by ben2008 BadBob, stoney, Dave Monk and 1 other 4 Quote
Rockytime Posted May 19, 2021 Author Report Posted May 19, 2021 Cute little tool. I'll have to consider it. Over the years I've purchased many things from them. OCtoolguy and ben2008 2 Quote
new2woodwrk Posted May 19, 2021 Report Posted May 19, 2021 I use both of the above HF file sets Also use a small torch for burning off fuzz I can't use the dremel tool for sanding as my hands shake too much OCtoolguy 1 Quote
Rockytime Posted May 19, 2021 Author Report Posted May 19, 2021 On 5/19/2021 at 8:39 PM, new2woodwrk said: I use both of the above HF file sets Also use a small torch for burning off fuzz I can't use the dremel tool for sanding as my hands shake too much Expand Understood . I have neuropathy causing some shaking . new2woodwrk and OCtoolguy 2 Quote
CSull Posted May 19, 2021 Report Posted May 19, 2021 I bought a set of needle files from Grizzly Tools and at first I thought they would be to fine but have worked out well. OCtoolguy 1 Quote
Rockytime Posted May 25, 2021 Author Report Posted May 25, 2021 Just got these from Amazon today. They were $5.94. They had a lot of bad reviews claiming they were not diamond, flimsy, etc. Actually I am amazed how nice they are. They are diamond and are perfect for tiny areas. They are an assorted group of 10. I'd call them a bargain. ben2008 and OCtoolguy 1 1 Quote
OCtoolguy Posted May 25, 2021 Report Posted May 25, 2021 On 5/25/2021 at 1:33 AM, Rockytime said: Just got these from Amazon today. They were $5.94. They had a lot of bad reviews claiming they were not diamond, flimsy, etc. Actually I am amazed how nice they are. They are diamond and are perfect for tiny areas. They are an assorted group of 10. I'd call them a bargain. Expand Les. can you supply a link? Quote
Rockytime Posted May 25, 2021 Author Report Posted May 25, 2021 On 5/25/2021 at 1:53 AM, octoolguy said: Les. can you supply a link? Expand I'm not sure how to do that but if you look for diamond files in Amazon it will be pretty hard to miss. Only one there for $5.94. OCtoolguy 1 Quote
OCtoolguy Posted May 25, 2021 Report Posted May 25, 2021 On 5/25/2021 at 2:31 AM, Rockytime said: I'm not sure how to do that but if you look for diamond files in Amazon it will be pretty hard to miss. Only one there for $5.94. Expand Les, when you go to Amazon and find the ones you bought, go up to the address bar, click on it and then right click. It will give you an option to copy. So copy it and then go to this place on SSV and right click again. This time, instead of copy, hit paste. That will place the link where you want it. Rockytime 1 Quote
OCtoolguy Posted May 25, 2021 Report Posted May 25, 2021 I went to Amazon and typed in diamond files. I found nothing in that price range. Quote
BadBob Posted May 25, 2021 Report Posted May 25, 2021 Search amazon for diamond needle file. Then switch the search to "low to high." Scroll down until you find one yo like. There are lots of them. OCtoolguy 1 Quote
Rockytime Posted May 26, 2021 Author Report Posted May 26, 2021 On 5/25/2021 at 2:59 AM, octoolguy said: I went to Amazon and typed in diamond files. I found nothing in that price range. Expand I went back on Amazon and could not find it either. Found several for $6 and a bit more. Went to the reorder part on Amazon and can reorder but the price is $5.50. I don't quite get it. As with 3M stuff prices keep changing. Weird. OCtoolguy 1 Quote
Jim McDonald Posted May 26, 2021 Report Posted May 26, 2021 On 5/25/2021 at 1:33 AM, Rockytime said: Just got these from Amazon today. They were $5.94. They had a lot of bad reviews claiming they were not diamond, flimsy, etc. Actually I am amazed how nice they are. They are diamond and are perfect for tiny areas. They are an assorted group of 10. I'd call them a bargain. Expand Les: I have a line gauge that looks very similar. Mine is 18" and I use it all the time. Traded some darkroom time for my gauge after I had left the paper, but they asked me back to do a special one off job. OCtoolguy 1 Quote
Rockytime Posted May 27, 2021 Author Report Posted May 27, 2021 On 5/26/2021 at 9:59 PM, Jim McDonald said: Les: I have a line gauge that looks very similar. Mine is 18" and I use it all the time. Traded some darkroom time for my gauge after I had left the paper, but they asked me back to do a special one off job. Expand WOW, not too many know what a line gauge is. I've used one for 68 years. Started in the printing industry working in a country weekly newspaper in a small town when I was 14. I'm 82 and still use it. The printing industry was good to me. I worked in news papers and eventually owned a printing and graphics plant for 30 years and now I still use the line gauge. It never leaves me. OCtoolguy 1 Quote
