Jim Erickson Posted May 20, 2021 Report Share Posted May 20, 2021 I think I want an inclinometer so I can accurately set the table tilt on my Hawk scroll saw. Do I need one, and if so which one should I buy. I'd appreciate comments and experiences. I could also use it for my table saw. Thanks for the help. Jim OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted May 20, 2021 Report Share Posted May 20, 2021 If you're wanting to tilt the table for cutting angles you don't use an inclinometer, use a digital protractor like a Wixey found on Amazon. Very inexpensive. Works great on the table saw. The Wixey is magnetic so hopfully your table is cast iron or steel, otherwise you can still hold it. Dave Monk, OCtoolguy and WayneMahler 2 1 Quote Link to comment Share on other sites More sharing options...
Jim Erickson Posted May 20, 2021 Author Report Share Posted May 20, 2021 Table is aluminum. Digital protractor eh? Thanks. Jim OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Jim Erickson Posted May 20, 2021 Author Report Share Posted May 20, 2021 What size? Thanks. Jim OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted May 20, 2021 Report Share Posted May 20, 2021 I've been using this one for all my saws For my scroll saw though, to get it balanced I still just use a piece of wood and manually adjust it OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
flarud Posted May 20, 2021 Report Share Posted May 20, 2021 (edited) I use this one, very similar to the one new2woodwrk posted. https://www.amazon.com/Wixey-WR300-Type-Digital-Backlight/dp/B00T6YZ0K6/ref=pd_sbs_1/144-3754990-2617927?pd_rd_w=S2oLQ&pf_rd_p=c6f9e951-390f-460a-badd-ad329bcd73f1&pf_rd_r=8XQN3MQF1VM768CY8T1Y&pd_rd_r=03f07214-23c4-44a6-950a-75229137169a&pd_rd_wg=vt71N&pd_rd_i=B00T6YZ0K6&psc=1 Edited May 20, 2021 by flarud OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Ceric ME Posted May 20, 2021 Report Share Posted May 20, 2021 I've been using a cheap analog gauge for degrees from Harbor Freight. You have to wait for it to settle down but it's alright. The digital ones are nicer. Just make sure the Table/Stand you saw is on is 0 degree or it won't work correctly. I've also tried to use an angle finder, the type you can put to an angle and then lock down, it's just to long for what I'm trying to do. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted May 20, 2021 Report Share Posted May 20, 2021 If you have certain angles you commonly use you can just make some cuts into a block of scrap wood at the desired angles. I have one I use regularly to check to make sure the table is square and didn't get moved. If it fits on the front and spin it around to the back side of the blade and it fits in the slot the blade is at 90 OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
WayneMahler Posted May 20, 2021 Report Share Posted May 20, 2021 I use the one made by iGuaging. Same size and functions as the Wixey . I do a lot of different angles and this makes it easy. Can move it to the scroll saw, drill press, table saw, band saw and works great for all of them. Here is the link for the Wixey Gauge at Amazon. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
TAIrving Posted May 21, 2021 Report Share Posted May 21, 2021 There is an app on my iPhone to measure inclination. It is in my "Utilities" app, "Measure" and "Level". If you have an iPhone you might try that and let us know if it works for this purpose. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
oldhudson Posted May 21, 2021 Report Share Posted May 21, 2021 21 hours ago, Jim Erickson said: Table is aluminum. Digital protractor eh? Thanks. Jim Here's a link to the Wixey digital angle gauge. https://www.amazon.com/Wixey-WR300-Type-Digital-Backlight/dp/B00T6YZ0K6/ref=sr_1_3?crid=78J10XSPNH82&dchild=1&keywords=wixey+digital+angle+gauge&qid=1621609852&sprefix=wixe%2Caps%2C209&sr=8-3 I've had one for about 10 years. Works great. As Les noted it has a magnetic base. No problem for an aluminum table. My table saw table is aluminum, no issues. One thing of note, at least in mine. For some reason it always seems to draw current, even when off. So it's best to remove the battery when not in use. I've never used it on a scroll saw, I use a small tri square. Nothing I do on a scroll saw needs any more accuracy than that. Quote Link to comment Share on other sites More sharing options...
Rockytime Posted May 21, 2021 Report Share Posted May 21, 2021 5 hours ago, Algae said: There is an app on my iPhone to measure inclination. It is in my "Utilities" app, "Measure" and "Level". If you have an iPhone you might try that and let us know if it works for this purpose. I have two of these apps on my phone. They are close but no cigar. The Wixey is very accurate . danny and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
