34 minutes ago, Rockytime said:
You would consider water around your machines?
When I was cutting aluminum I did drip cutting oil every so often.  Not a constant drip.
Also I did put the dust collector funnel under the blade.  So a small bit of oil did not hurt or make a mess.
Hawk and I believe Hegner also has a water tank system for cutting metals etc.  where you would need cooling. I don't have any experience with them just noticed them on the accessories page.
This look like a plastic cutting material my wife uses. She throws it out (gives it to me) if it get too chopped up. I have a few and they are about 1/2" thick and I will cut them close to the shape I need with the band saw and shape it with either a belt sander or oscillating sander.  I've used it for my band saw insert and an elevated stand for our Zero Water filter.
Well I am going just the reverse, I was making some signs for my Son in Law out of Plexi Glass, I started slow, same problem melting back together, I sped up my saw, end of problem. I couldn't tell you what blade  I was using. to many yrs back. The Plexi was 1/4 thick.😀
I have cut Plexiglass years ago and there was someone in Tenesee who sold supplies for scroll saw folks and had picnics back in the day. Can not remember the name but got stuff from them but they are closed up now. Any way he used duct tape over the Plexi then pattern and very slow speed. I did this and it worked well unless speed increase then you would have melt and stick to gather. Made ornaments, birds, etc.
