new2woodwrk Posted June 14, 2021 Report Share Posted June 14, 2021 (edited) Here's an odd question: Has anyone come up with a method to use more of the blade? I notice that there is only about 1/3 or so of the total length of the blade that is actually used. Now I realize blades are one of the least expensive items used in scrolling, but I'm thrifty (meaning cheap LOL) I was thinking maybe someone came up with a way to use more of the blade. what comes to mind is a platform placed on top of the table to raise the cutting piece and use more of the top of the blade? I know that negates the effect of having the bottom teeth pointing up but you never know Anyway, just wondering - it was on my mind so thought I'd post it. Thanks as always in advance Edited June 14, 2021 by new2woodwrk OCtoolguy and lawson56 2 Quote Link to comment Share on other sites More sharing options...
Denny Knappen Posted June 14, 2021 Report Share Posted June 14, 2021 I know others talked about this, but I wonder why when blades are less than 25 cents. OCtoolguy, Jim McDonald and new2woodwrk 2 1 Quote Link to comment Share on other sites More sharing options...
ben2008 Posted June 14, 2021 Report Share Posted June 14, 2021 (edited) You could try the Olson or FD blades "Two way cut Crown Tooth" that cut either way. When it gets dull you flip the blade over 180 degrees and continue cutting. It does work as long as the blade is not to bent up. I use them occasionally. They are not the sharpest, but on the other hand, you are using the whole blade and you have more control. If you are looking for speed, don't bother. If you are looking for accuracy and nice clean cuts,they may work for you. They do take some getting used too. Just my opinion. Ben Edited June 14, 2021 by ben2008 OCtoolguy, tomsteve and new2woodwrk 2 1 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted June 14, 2021 Report Share Posted June 14, 2021 (edited) Waste not, want not! I'm frugal so I'll try these suggestions. Save 4 blades, that's a dollar! For those of you who think I'm serious here, well, I'm not. Blades are cheap! Edited June 18, 2021 by octoolguy new2woodwrk, tomsteve and ben2008 3 Quote Link to comment Share on other sites More sharing options...
ben2008 Posted June 14, 2021 Report Share Posted June 14, 2021 Ray The FD "2 way cut" at Mikes are just 25 cents ea. for a 12 pack, with free shipping. You don't need to buy a gross either. https://mikesworkshop.com/products/tc-2-way-cut Ben danny, tomsteve and OCtoolguy 2 1 Quote Link to comment Share on other sites More sharing options...
ben2008 Posted June 14, 2021 Report Share Posted June 14, 2021 2 hours ago, Denny Knappen said: I know others talked about this, but I wonder why when blades are less than 25 cents. Denny You have to buy a gross to get near that price. Some of us don't want to buy a gross every time we need a few blades to finish a project. I have that problem right now. I literally have hundreds of blades that I will probably never use because i bought too many to begin with. Assortment packs are nice only if you use them. OCtoolguy and tomsteve 1 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted June 14, 2021 Report Share Posted June 14, 2021 I always used to flip my blades end for end when I used the FD-UR blades.. They are similar to the two way cut blades with reverse teeth throughout the blade. I have also just flipped regular reverse tooth blades etc.. But sawing on the Hawk I find that once the blade starts getting dull it usually breaks soon. Taking the time to undo the blade and flip it for it to only last a couple more cutouts isn't worth my time to do. SO I just run them until they break, LOL. If you flip a blade expect it to cut a few degrees off on the opposite side that it normally cuts on. Takes a bit to get used to and many might ruin a project if they aren't careful. I got pretty good and just cutting with whatever blade and whatever way it's installed. It teaches one to learn to let the blade do the cutting and don't push it, just steer it, LOL tomsteve, new2woodwrk and OCtoolguy 2 1 Quote Link to comment Share on other sites More sharing options...
CharleyL Posted June 14, 2021 Report Share Posted June 14, 2021 I wouldn't bother for the low cost of the blades, but attaching a 3/4 or 1" thick piece of wood to your saw table, with a hole in it for the blade to pass through, should let you use a higher portion of the blade. It's your decision if going to this trouble is worth doing. If you do, make certain that you don't suddenly decide to cut something thicker (like a stack cut) that exceeds the stroke length that is left to work with or you will likely damage your saw. No thanks, I'll keep using my blades without worrying about the unused teeth of the blades and just keep replacing them when they go dull or break at less than $0.25/blade. Charley tomsteve, new2woodwrk and OCtoolguy 2 1 Quote Link to comment Share on other sites More sharing options...
Denny Knappen Posted June 14, 2021 Report Share Posted June 14, 2021 2 hours ago, ben2008 said: Denny You have to buy a gross to get near that price. Some of us don't want to buy a gross every time we need a few blades to finish a project. I have that problem right now. I literally have hundreds of blades that I will probably never use because i bought too many to begin with. Assortment packs are nice only if you use them. I sell repackaged dozen packs at the gross price ( not on the website). For example a gross of MGT blades are $35 per pack. My repackaged dozen pack is $2.92 or just under 25 cents. No minimum and shipping is $3.50. If you order $35 or more, shipping is free. If interested, email me at artcraftersscrollsaw@gmail.com. barb.j.enders and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
ben2008 Posted June 14, 2021 Report Share Posted June 14, 2021 1 hour ago, Denny Knappen said: I sell repackaged dozen packs at the gross price ( not on the website). For example a gross of MGT blades are $35 per pack. My repackaged dozen pack is $2.92 or just under 25 cents. No minimum and shipping is $3.50. If you order $35 or more, shipping is free. If interested, email me at artcraftersscrollsaw@gmail.com. I'll keep that in mind. I'm still using some of the assortment I purchased from you a few months ago. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Jim Finn Posted June 15, 2021 Report Share Posted June 15, 2021 In the past, I have cut the bottom 1/2" of the dull blade off. This works well if your saw will accommodate the shortened blade. new2woodwrk, OCtoolguy and danny 3 Quote Link to comment Share on other sites More sharing options...
kywoodmaster Posted June 15, 2021 Report Share Posted June 15, 2021 The Olsen crown tooth has always been my favorite blade. You have to learn when to change ends add not push them too far before you make the change. Yes the will track off in the opposite direction when you change. new2woodwrk, OCtoolguy and ben2008 3 Quote Link to comment Share on other sites More sharing options...
Karl S Posted June 15, 2021 Report Share Posted June 15, 2021 Blades are the cheapest part of scrolling, My thoughts are if you c an't afford a .$25 cent blade then you need to find a different hobby. Perhaps I am fortunate enough to be able to afford blades, so I don't even give it a thought about what one costs. I don't mean to offend you but there are costs to all hobbies and some of them are very expensive .Don't worry about the cost, just enjoy what you are doing. OCtoolguy and barb.j.enders 2 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted June 15, 2021 Report Share Posted June 15, 2021 Scrolling is the most inexpensive hobby I've found. Pen turning can be very expensive unless you sell everything you make. Then machining. Many thousands of $. I've gotten rid of everything except my scroll saws. I've thought of perhaps collecting used shoe strings.That would be inexpensive. ben2008, OCtoolguy, tomsteve and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
Joe W. Posted June 15, 2021 Report Share Posted June 15, 2021 I came across a utube video a few months back (and can't find it now, dang it) of a man who made a template of his scroll saw table out of wood and put it on top of his scroll saw table for just that purpose - to use all of the blade. I think it's a clever idea, but for me, it complicates things and adds more time to the process for that little bit of extra blade use. Now, here's a thought - if you really want to make your next million, invent a scroll saw with an adjustable table that not only tilts side to side, but could easily be adjusted to raise and lower to enable you to use the unused portion of the scroll saw blade. Oh, and if you make that million, I would appreciate an idea fee of 1/2% of that million. OCtoolguy and new2woodwrk 1 1 Quote Link to comment Share on other sites More sharing options...
Tom-in-Ashland Posted June 16, 2021 Report Share Posted June 16, 2021 But then your reverse skip blade would be just a skip. tomsteve and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
MrsN Posted June 16, 2021 Report Share Posted June 16, 2021 I would have thought that after using the blade in the normal position it would become slightly weaker in that section and more prone to breaking if used in an elevated position. danny, new2woodwrk, tomsteve and 1 other 4 Quote Link to comment Share on other sites More sharing options...
Davevand Posted June 16, 2021 Report Share Posted June 16, 2021 (edited) 21 hours ago, Joe W. said: I came across a utube video a few months back (and can't find it now, dang it) of a man who made a template of his scroll saw table out of wood and put it on top of his scroll saw table for just that purpose - to use all of the blade. I think it's a clever idea, but for me, it complicates things and adds more time to the process for that little bit of extra blade use. Now, here's a thought - if you really want to make your next million, invent a scroll saw with an adjustable table that not only tilts side to side, but could easily be adjusted to raise and lower to enable you to use the unused portion of the scroll saw blade. Oh, and if you make that million, I would appreciate an idea fee of 1/2% of that million. I do this when I am cutting out toys to give away. I use a skip tooth blade to cut the toys, when it get dull I have a 1" thick piece of plywood that I put down on my scroll saw table and continue cutting, it almost doubles the life of the blades. Edited June 16, 2021 by Davevand Jim Finn and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted June 16, 2021 Report Share Posted June 16, 2021 At todays prices for plywood to make a riser table to get more from a blade.. I think maybe throwing out the blade is a cheaper option, .. Then again, I go through half a dozen + blades per day.. Usually order 2-5 gross of each size / style blade I use the most when I order, and I always order when I get to my last gross package so hopefully I don't run out. At any rate, It'd take a long time and a lot of blades to pay for the plywood material just so you could save a few penny's on blades. OCtoolguy and Dave Monk 2 Quote Link to comment Share on other sites More sharing options...
Norm Fengstad Posted June 17, 2021 Report Share Posted June 17, 2021 I wondered about elevating the table with a 3/4 piece and even tried it once it is doable and in some projects might be worth it . Mostly though blades are bent, weakened or stretched new2woodwrk, OCtoolguy and danny 3 Quote Link to comment Share on other sites More sharing options...
Wichman Posted June 18, 2021 Report Share Posted June 18, 2021 Back in the day. 1985, I started with a sears knockoff of a Dremel scrollsaw 13" used 3 inch pinned blades, 3 types available; 7 tpi, 20 tpi, and 25 tpi. Learned lots of tricks with that saw. It had an adjustable height table designed so you could use "all the blade". So I tried, results were never very satisfactory. Even tried starting in a raised position and moving down. Maybe it was just me... new2woodwrk and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
Fab4 Posted June 18, 2021 Report Share Posted June 18, 2021 4 hours ago, Wichman said: Back in the day. 1985, I started with a sears knockoff of a Dremel scrollsaw 13" used 3 inch pinned blades, 3 types available; 7 tpi, 20 tpi, and 25 tpi. Learned lots of tricks with that saw. It had an adjustable height table designed so you could use "all the blade". So I tried, results were never very satisfactory. Even tried starting in a raised position and moving down. Maybe it was just me... Hi Wichita: Did your Dremel come with a sander attachment? I still have mine and blades too - This was my starter saw also, back in the day It's a little saw that makes big noise...lol I found that raising the table, the stroke of the blade was not the same and made it slightly different to cut Fab4 OCtoolguy and new2woodwrk 2 Quote Link to comment Share on other sites More sharing options...
crupiea Posted August 9, 2021 Report Share Posted August 9, 2021 I dont sweat the blades too much. Funny that I can go through one blade for an entire project, next day go through 5 just doing something small. Always feel its me when blades are breaking a lot. That said, I also use blades until they break. I have no issues using an old rusty bent blade as long as I can feed it through the wood. I have been using the same dozen #3 fd blades for about 10 years, srs. Broke one recently and honestly could not remember the last time I did. I only use them for cutting large pieces to size and such though so they dont get a lot of use. My go to blades are jewelers 2/0 and they are only $20 a gross on amazon so can break alot before I feel it. Quote Link to comment Share on other sites More sharing options...
teachnlearn Posted August 9, 2021 Report Share Posted August 9, 2021 Scrollsaw softer materials, one suggestion is Jello. RJF Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted August 9, 2021 Report Share Posted August 9, 2021 48 minutes ago, teachnlearn said: Scrollsaw softer materials, one suggestion is Jello. RJF Been there done that.. Jello bounces too much and can't see the lines.. don't slide on the table the best either, Quote Link to comment Share on other sites More sharing options...
