preprius Posted June 26, 2021 Author Report Posted June 26, 2021 Ok its friday night I can go back to the scroll saw and try all these tips and tricks. I am building flower to feed my flock of hummingbirds. Then make another flock flying in from the left. And I want to thank everybody for pitching in there 2 cents. I really appreciate it. It was a good topic for us newbies to learn tip and tricks. stoney and OCtoolguy 2 Quote
Woodrush Posted June 26, 2021 Report Posted June 26, 2021 On 6/23/2021 at 5:25 PM, preprius said: i have tried flying dutchman and these pic use pegas. 2/0 skip and 2/0 mgt. Hawk . I feel that non skip blades allows more teeth to cut both sides of blades. With skip I think they skipped one side of the blade. Rotating the wood counter clockwise is worse than rotating the wood clockwise. Try the pegas super skip. That's all I use OCtoolguy 1 Quote
preprius Posted June 27, 2021 Author Report Posted June 27, 2021 (edited) Update. . . I did make the blade tighter. in fact a bit too tight. I stuck with mgt 2/0. I ran 1 blade for awhile. the next 2 blades just popped. So I backed off the tension just a bit. Seems to do much better. I did not try the 2/0 skip. Yellow heart and paduak. 1/4 inch. Looks like I will need to touch up some places for a better fit. Now for giving it depth. Need to get some grooves going. Again thanks for advice, tips, tricks. Edited June 27, 2021 by preprius OCtoolguy 1 Quote
OCtoolguy Posted June 29, 2021 Report Posted June 29, 2021 I just ran across this picture that I had saved on my computer. It might clear up the whole angled cut thing. Rockytime and BadBob 1 1 Quote
preprius Posted June 29, 2021 Author Report Posted June 29, 2021 Yep that picture is the same as as I thought. It is just a matter of preference and how the blade reacts. Oh and tension of the blade. gritting teeth because I'm tense. OCtoolguy 1 Quote
