Buterfly and Flowers
FrankEV
Questions:
On the red flowers is the dark red the only raised area?  The light red is backer board?
Is this the same with light blue on butterfly?
Me not knowing, does the wood need to be primed for acrylic paint?
The green stems swirls got a bit thin.  Maybe the pattern needs to be tweaked.  My idea is super thin wont add much to the art piece.  But a broken piece will detract from product.
the following comments are just future thought and probably stupid ideas.
Since the butterfly is not part of the backer, mount the butterfly on spring steel wire so it can move in the breeze or if you touch it.  This will change the viewers attention but will also have potential to degrade from fine art to cute idea.
By the way ,
The piece is beautiful.
1 hour ago, preprius said:
Questions:
By the way ,
Answering the questions out of order:
Only one place is the geen stem very thin due to me wandering off the line a little.  I was able to hold the cut panel in my hand for painting without concern.  After it is glued to the backer, yes if struck  or the like,  a piece could be broken off. True of any "positive" type cuts.  Fine Art is delicate and should be treated as such.
The light Red, light Green, Blue and white are painted on the backer.
The cut piece is painted with the darker Red, Darker Green and Black.
It is a good idea to prime the wood with a Acrrylic Gesso (white art primer) before painting.  However, that becomes VERY difficult for the painted areas on the backer.  The spaces under the cut panel is so narrow it is hard to keep from going beyond the colored area.  I did not prime but did apply multiple coats of paint.  Priming the wood makes the paint flow easier and lay more evenly.  Finishing with a coat of lacquer tends to even things out nicely.
Now to that orther idea....nah!
