After dealing with worn out clamps on my EX-16, thought it was time for an upgrade. I am a top feeder and had replaced my bottom clamp once and even put in a helicoil in the thread but everything eventually it all got too wobbly. Called Denny at Artcrafters and had my replacement in 3 days! I took my deck off and it made for a much easier replacement. The top was in actually in good shape but the bottom was a different story. Needle bearings were a little dirty and didn't rotate properly but with a little cleaning, they were back to good working order. Actual replacement on both the top and bottom were very easy. I figured out a while back that having the thumb screw on the left on the bottom worked better for me so I could position the blade with my right hand. Moved the stop screw to the right side with no problem. No major tension adjustments needed and all is working well. Thanks Denny for quick delivery and and answering some set up questions.
Edited by munzieb
