Very nice and well done.
Quick question. I've seen you mention this before but never asked: Why do you use the diluted Shallac, prior to spraying with the Lacquer?
I recently bought a can of Shallac to try this process, but just haven't gotten around to trying it.
I have finished many wood working projects, both prior to getting into scrolling and now for my scrolling projects,  just with Lacquer
Thanks Frank.  For me, Shellac right out of the can is too thick.  Diluting it 50% with denatured alcohol makes it thin enough to act as a sanding sealer.  Usually I dip in the solution and let air dry.  After a light sanding, it is ready to finish.
23 hours ago, Denny Knappen said:
...act as a sanding sealer.  Usually I dip in the solution and let air dry.  After a light sanding, it is ready to finish.
I have, and have used a few time in the past, Deft Sanding Sealer for that same purpose.  However, It has a silight tendency to add a little yelowish darkening of the wood, more so than just using straight Lacquer.  When wood like Maple, or even BB, is left un- stained, I want the wood color to remain as natural as possible through the final finish.
I do most of my sanding pre-cutting and only do a little touch up sanding if absolutely necessary, so the need for a sanding sealer in my opinion is not as important for scroll saw panels as it is for wnen making furniture or other large projects that require extensive finish sanding afer assenbly.
Thanks for the reply.  I'm always egar to learn what other processes people do and why.
I find by dipping, the solution gets into all the little frets which spray seems to miss.
