Wichman Posted July 17, 2021 Report Posted July 17, 2021 Here is a custom unique piece at the request of a customer. It's a name in Arabic. 1 1/4" X 1/3/4" x 1/4 unknown wood, probably a maple. Cut with a FD polar # 2 followed by a spiral blade. Used bits of toothpicks to support the center of the right hand letter, used superglue to attach the piece; then a light coat of superglue on all surfaces, buffed and then 2 coats of clear, gloss, spar varnish: frankorona, lawson56, RabidAlien and 6 others 9 Quote
lawson56 Posted July 17, 2021 Report Posted July 17, 2021 Beautiful job Your customer will be Very Well pleased. Quote
FrankEV Posted July 17, 2021 Report Posted July 17, 2021 Nice job. Back when I had my shop in NC and used to turn bowls and such, I often used to use superglue as a finish. Easy to do when the work was turning, Never thought of using to finish a small piece like your pendant. I suspect you have to work very quickly and it must be difficult not to glue your fingers to the piece . Quote
Wichman Posted July 17, 2021 Author Report Posted July 17, 2021 Frank, I had two reasons for the superglue; 1. when I glued the small piece in it was not possible to just glue the piece, there was some overflow, so I just continued and coated the whole piece. 2. I wanted to toughen and stabilize the piece. The superglue absorbed into the wood very readily and I didn't stick my fingers at all. FrankEV 1 Quote
