Very nice!  I love how you painted it.  I appreciate all the details on how you made it.  I would have used about that many blades also.  I always thought I was doing something wrong because I needed so many blades, but maybe not.  Thanks for sharing!
1 hour ago, TexasDIY said:
...I would have used about that many blades also.  I always thought I was doing something wrong because I needed so many blades...
I did good using ony 15 blades for that many holes.  It is the rethreading that tends to kink the small blades and then they break even if not dull yet.  If I 'm real carefull and  make sure I pull up on the blade each time I rethread the blade, I can get a lot more cuts done before it breaks.   I have also found I don't need to tioghten the thumb screw toooo tight so the blade does not bend at the clamp.  Also helps keep the blades from breaking.
