OCtoolguy Posted August 5, 2021 Report Share Posted August 5, 2021 3 hours ago, kmmcrafts said: Never understood why they make those bellows out of that goofy rubber/plastic stuff.. I see most used saws needing that piece.. I see Hawk list the bellows for their saws for $10.. I've also never ever heard or seen of anyone having to replace one on a Hawk.. They are listed in the parts on their site so I'm sure people buy them.. It's just not very common like on the Hegners.. Hegners are dam good saws.. but I do feel they could improve on a lot of things.. as can Hawk.. Hawk in my mind would be quite a competitor to Hegner if they had good management for the company like Hegner does.. If I owned a Hegner I'd have to buy stocks in Magnifier light bulbs and lenses.. My older Hawk upper arm goes up higher than the other newer Hawks. I've broke two bulbs and cracked a magnifier lens from that arm when a blade broke.. Not sure why Hegner designed that front tension lever to stick up 3-4 inch above the arm, Was always kind of curious if the designers of scroll saws ever used one.. Sort of like Rv's. The designers have obviously never RV'd. It takes a woman to design a kitchen and bathroom. The guys should design the driver's compartment and outside storage bays. kmmcrafts 1 Quote Link to comment Share on other sites More sharing options...
SCROLLERNATION Posted August 5, 2021 Author Report Share Posted August 5, 2021 6 hours ago, kmmcrafts said: Never understood why they make those bellows out of that goofy rubber/plastic stuff.. I see most used saws needing that piece.. I see Hawk list the bellows for their saws for $10.. I've also never ever heard or seen of anyone having to replace one on a Hawk.. They are listed in the parts on their site so I'm sure people buy them.. It's just not very common like on the Hegners.. Hegners are dam good saws.. but I do feel they could improve on a lot of things.. as can Hawk.. Hawk in my mind would be quite a competitor to Hegner if they had good management for the company like Hegner does.. If I owned a Hegner I'd have to buy stocks in Magnifier light bulbs and lenses.. My older Hawk upper arm goes up higher than the other newer Hawks. I've broke two bulbs and cracked a magnifier lens from that arm when a blade broke.. Not sure why Hegner designed that front tension lever to stick up 3-4 inch above the arm, Was always kind of curious if the designers of scroll saws ever used one.. I've replaced a bellows on an old ac motor hawk. But only one so far because its good rubber. And one scrollmate because it hd been sitting for a long time. The new hawk arms dont go up as high as my ultra series? OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
SCROLLERNATION Posted August 5, 2021 Author Report Share Posted August 5, 2021 Its a little more loud because of the phone. It is almost as loud as an old Delta 40-601. IMG_4736.MOV OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted August 5, 2021 Report Share Posted August 5, 2021 4 hours ago, octoolguy said: Sort of like Rv's. The designers have obviously never RV'd. It takes a woman to design a kitchen and bathroom. The guys should design the driver's compartment and outside storage bays. Having had a RV and currently a 5th wheel TT I totally understand where you're at with this. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted August 5, 2021 Report Share Posted August 5, 2021 1 hour ago, SCROLLERNATION said: I've replaced a bellows on an old ac motor hawk. But only one so far because its good rubber. And one scrollmate because it hd been sitting for a long time. The new hawk arms dont go up as high as my ultra series? The new Hawk and the Ultra seem to go up about the same amount... The old 1993 220VS goes way up.. come to think of it.. I'm not sure if it has the bolt in the back that acts as a stop.. maybe that's why it goes up so high.. It's really nice on those really large projects if you feed the blade from the bottom.. Maybe I should keep that saw, LOL.. Rolf, SCROLLERNATION and OCtoolguy 3 Quote Link to comment Share on other sites More sharing options...
SCROLLERNATION Posted August 5, 2021 Author Report Share Posted August 5, 2021 40 minutes ago, kmmcrafts said: The new Hawk and the Ultra seem to go up about the same amount... The old 1993 220VS goes way up.. come to think of it.. I'm not sure if it has the bolt in the back that acts as a stop.. maybe that's why it goes up so high.. It's really nice on those really large projects if you feed the blade from the bottom.. Maybe I should keep that saw, LOL.. I keep telling you don’t get rid of it. lol you will miss it. I just hope with those long arms on my 26 itll go up high. I like that with the blade coming forward its easier kmmcrafts and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted August 5, 2021 Report Share Posted August 5, 2021 29 minutes ago, SCROLLERNATION said: I keep telling you don’t get rid of it. lol you will miss it. I just hope with those long arms on my 26 itll go up high. I like that with the blade coming forward its easier Can always take the stopper bolt out and it'll go way up.. just don't hover over it and get a tooth knocked out if a blade breaks, .. Not a big fan of drilling holes in saws, especially new ones.. but you could drill the hole lower and install the stopper bolt so the arms comes up higher if needed. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
SCROLLERNATION Posted August 5, 2021 Author Report Share Posted August 5, 2021 8 minutes ago, kmmcrafts said: Can always take the stopper bolt out and it'll go way up.. just don't hover over it and get a tooth knocked out if a blade breaks, .. Not a big fan of drilling holes in saws, especially new ones.. but you could drill the hole lower and install the stopper bolt so the arms comes up higher if needed. lol no. No modifications! I’ll live. The only saw i have that pops up violent is my ps wood. When that arm comes up look out! OCtoolguy and kmmcrafts 2 Quote Link to comment Share on other sites More sharing options...
Rolf Posted August 5, 2021 Report Share Posted August 5, 2021 On 8/3/2021 at 9:05 PM, Scrappile said: Wolfgang is not the gentleman that passed away a year or so ago?? I believe it was his brother, Hans that passed. I used to enjoy speaking German with him. We used to tease each other about the Hegner VS Hawk. He was a true gentleman. kmmcrafts, OCtoolguy, SCROLLERNATION and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) Making the arm on a Hegner raise higher is an easy modification that a few of us here have done.. Yes, @Rolf, now that you mention the name... it was Hans that passed. He was a great person to talk with,,,,even in english.. Edited August 5, 2021 by Scrappile OCtoolguy and Jim Finn 2 Quote Link to comment Share on other sites More sharing options...
ben2008 Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) 14 hours ago, octoolguy said: How could anybody not like a brand new Hegner? It's not the point of liking, it's the need. I now have 3 saws. A 29 year old RBI Hawk, a 9 year old Excalibur,, and a 1 month old 14" Jet. All work perfectly and I use all 3. I like a lot of things. I just don't need them. or can afford them. One final comment. I have never operated a Hegner, so I have no idea if I would like one. Edited August 5, 2021 by ben2008 OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
