Unfortunately, I live alone.. sooo.. LOL.     I have a plastic tube set up I bought, but when I bought my used dewalt, the guy I got it from used small pieces of like 1/2" ID pvc pipe, that he cut to like 5.5" and glued a cap to one end, and the other end it just slips on.  Then he had one spring loaded tool holders to keep them mounted on the saw stand.  These aren't the exact ones, The ones he used did not have the actual springs.
10Pcs Shovel Holder Wall Mount Garden Tool Organizer Broom Mop Spring Grip  Clamp - Walmart.com - Walmart.com
On 9/5/2021 at 6:58 AM, William Eicehelberger said:
I use 1/2 in tubes they won't hold a gross of blades, yours looks like thy would. I like it,
IKIE
I use 1/2" tubes and they hold gross of blades. I bought a set from Amazon that is a plastic rack with 60 tubes for about $15.
To edit: I checked my tubes and you are correct. They don't hold a gross of blades. I was thinking they did. Ooops!
Edited by OCtoolguy
