I have a puzzle pattern to cut, and a state map I want to attach to the finished pattern. I was thinking about how to best do it.
Cut pattern and attach picture to the cut out, or is their a better option possibly attach the picture to wood, spray something to protect picture then use masking tape over picture and attach puzzle pattern to the masking tape.
I always glue the pattern to the wood first with Aleens tacky glue. Use a J roller to get rid of any bubbles. I let it sit overnight to make sure the glue is well cured. I then apply two coats of Krylon Triple Thick Glaze. Allow it to cure 24 hours. Then, I cut freehand. You can put a puzzle outline over your pattern like Steve Good does, but I find it unnecessary.
Good luck!
Edited by Dan
