Popular Post Eric67 Posted October 26, 2021 Popular Post Report Posted October 26, 2021 Hello everybody, my last work, it's always the last before the next no? (or isn't it?) I'm not satisfied that time but I present it to you anyway. I try to improve my self. Eric lawson56, Tomanydogs, Fish and 15 others 18 Quote
Dak0ta52 Posted October 26, 2021 Report Posted October 26, 2021 Nice project, Eric. I see nothing a little sanding wouldn't take care of. Something I've noticed when cutting, especially with wood such as pine, is the blade has a tendency to follow the grain when cutting with the grain and when cutting against the grain, the feed of the blade will slow down as it cuts through the hard portion of the wood and then speed up when it is pushed through the softer part of the grain. If you're not careful, it will make you drift off you lines. I notice this more with spiral blades. Anyway, this has been my experience. Others on the forum may have other ideas. Quote
Eric67 Posted October 26, 2021 Author Report Posted October 26, 2021 51 minutes ago, Dak0ta52 said: Nice project, Eric. I see nothing a little sanding wouldn't take care of. Something I've noticed when cutting, especially with wood such as pine, is the blade has a tendency to follow the grain when cutting with the grain and when cutting against the grain, the feed of the blade will slow down as it cuts through the hard portion of the wood and then speed up when it is pushed through the softer part of the grain. If you're not careful, it will make you drift off you lines. I notice this more with spiral blades. Anyway, this has been my experience. Others on the forum may have other ideas. Hello Dakota, thank you for your advice, it's very interesting. I have indeed noticed this phenomenon, depending on the grain of the wood, the behavior of the blade changes and it becomes difficult (for me) to control the trajectory. Eric Quote
lawson56 Posted October 26, 2021 Report Posted October 26, 2021 It looks Down Right Awesome to me. Quote
RabidAlien Posted October 29, 2021 Report Posted October 29, 2021 On 10/26/2021 at 3:22 PM, Eric67 said: Hello Dakota, thank you for your advice, it's very interesting. I have indeed noticed this phenomenon, depending on the grain of the wood, the behavior of the blade changes and it becomes difficult (for me) to control the trajectory. Eric I've noticed this tendency to "jump" gets more and more pronounced the duller the blade is. When it gets to the point that I start worrying about cutting into "good" wood, I figure its time to swap blades. Nicely cut, though! Mark SW 1 Quote
GusGustin Posted November 8, 2021 Report Posted November 8, 2021 Nice. From that book of circles ? Quote
Eric67 Posted November 8, 2021 Author Report Posted November 8, 2021 14 minutes ago, GusGustin said: Nice. From that book of circles ? Thanks Gus, I found they on the web. Quote
