jbrowning Posted October 28, 2021 Report Posted October 28, 2021 Good morning everyone, has anyone ever seen a picture or video of what the inside of a Hegner blade clamp looks like? I'm asking about the bottom clamp and the top clamp that has the wheel to turn and tighten it. Has anyone seen pictures of the inside of these clamps? I'm trying to visualize what they look like. Thanks Jim OCtoolguy 1 Quote
Foxfold Posted October 28, 2021 Report Posted October 28, 2021 (edited) Never looked inside. I know the bottom clamp comes in various sizes. I love mine. Although I have a hex screw in my bottom clamp. Edited October 28, 2021 by Foxfold jbrowning and OCtoolguy 2 Quote
OCtoolguy Posted October 28, 2021 Report Posted October 28, 2021 I'm trying to understand your question. What are you trying to get at? Are you referring to the "Quik clamp"? jbrowning 1 Quote
jbrowning Posted October 28, 2021 Author Report Posted October 28, 2021 Both, the quick clamp and the bottom clamp. Jim OCtoolguy 1 Quote
OCtoolguy Posted October 28, 2021 Report Posted October 28, 2021 2 minutes ago, jbrowning said: Both, the quick clamp and the bottom clamp. Jim They are made differently. The regular clamps are slotted clear through from front to back. The Quik clamp is only slotted back to the screw so the blade has a stop. jbrowning 1 Quote
Wichman Posted October 28, 2021 Report Posted October 28, 2021 (edited) The bottom clamp is similar to many other scroll saw clamps. The bolt pulls the sides together to clamp the blade between two flat surfaces. The quick clamp is very different. On the left side is an adjustable set screw to allow for wear. On the right side is a bolt with a knurled knob on the outside , the inside of the bolt resembles the end of a c-clamp, a rotating surface that is independent of the screw, this reduces the twisting force on the end of the blade. If you need them, I'll try to get pictures of mine. Edited October 28, 2021 by Wichman spelling OCtoolguy and jbrowning 1 1 Quote
jbrowning Posted October 29, 2021 Author Report Posted October 29, 2021 I appreciate your all's help. I'll go and see if I'm attaching the blades correctly or not. Thanks Jim OCtoolguy 1 Quote
Wichman Posted October 29, 2021 Report Posted October 29, 2021 10 minutes ago, jbrowning said: I appreciate your all's help. I'll go and see if I'm attaching the blades correctly or not. Thanks Jim Here's a video from the manufacturer: OCtoolguy, jbrowning and GrampaJim 2 1 Quote
OCtoolguy Posted October 29, 2021 Report Posted October 29, 2021 41 minutes ago, jbrowning said: I appreciate your all's help. I'll go and see if I'm attaching the blades correctly or not. Thanks Jim The main thing with the Quik clamp is it's tightened in the upper holder so that it can't rock. It stays locked in one place. In my estimation they should come out with a way to do the same on the lower clamp and do away completely with the old style clamps. It would be so much easier than having to load the clamp and then insert it into the lower arm. jbrowning 1 Quote
jbrowning Posted October 29, 2021 Author Report Posted October 29, 2021 Thank you both, things came up tonight so I wasn't able to get to the saw. But tomorrow I'm planning on getting to it and see what's going on with it. Thanks again Jim OCtoolguy and Wichman 2 Quote
OCtoolguy Posted October 29, 2021 Report Posted October 29, 2021 2 hours ago, jbrowning said: Thank you both, things came up tonight so I wasn't able to get to the saw. But tomorrow I'm planning on getting to it and see what's going on with it. Thanks again Jim We'll be awaiting your findings with bated breath. Lol. jbrowning 1 Quote
