carl1 Posted November 9, 2021 Report Posted November 9, 2021 I just made a Santa ornament and the actuating lines are narrower then the drill bit needed to start, the smallest i have are 1/16 . If you go smaller how do you get the blade threaded, I can barley get the blade in as is. What am I missing. Not good but here is pic of the ornament. OCtoolguy 1 Quote
Denny Knappen Posted November 9, 2021 Report Posted November 9, 2021 I use micro drill bits and it depends on the blade size. The micro drill bit I use most is #60. OCtoolguy 1 Quote
OCtoolguy Posted November 9, 2021 Report Posted November 9, 2021 1 hour ago, Denny Knappen said: I use micro drill bits and it depends on the blade size. The micro drill bit I use most is #60. I have numbers 56-60 and use the #58 the most. My problem is that I bought a 3 jaw adapter for my drill press and I can't get the bit to "center" in the chuck. My drill press is pretty tight so I know the problem is the tiny chuck. Any advice? I get pretty good job from my Dremel plunge router but it spins so fast it burns up the bits. If I slow it down, it has no power. Quote
Denny Knappen Posted November 9, 2021 Report Posted November 9, 2021 4 minutes ago, OCtoolguy said: I have numbers 56-60 and use the #58 the most. My problem is that I bought a 3 jaw adapter for my drill press and I can't get the bit to "center" in the chuck. My drill press is pretty tight so I know the problem is the tiny chuck. Any advice? I get pretty good job from my Dremel plunge router but it spins so fast it burns up the bits. If I slow it down, it has no power. Ray, I use a micro chuck head on the drill press at home. Here at ArtCrafters, use the Dremel. Quote
Dak0ta52 Posted November 9, 2021 Report Posted November 9, 2021 I use a Dremel plunge router also with a #60. I've got the new 4300 Dremel and haven't had any problem with power at a lower speed. If I have areas in the pattern that will accept a larger bit I'll use my drill press. I also have the smaller chuck to adapt my drill press to a smaller bit but found it didn't center as Ray experienced. When I want to use a bit in my drill press that is smaller than what it will clamp, I'll wrap a small copper wire around the base of the small bit and insert it into the drill press chuck. That seems to work pretty good. OCtoolguy and preprius 1 1 Quote
Mark SW Posted November 9, 2021 Report Posted November 9, 2021 I have never used it but maybe this might help. Best Scroll Saw Blades | Flying Dutchman | Hand Drill with Spring – Mike's Workshop | Flying Dutchman Scroll Saw Blades (mikesworkshop.com) I use my drill press and Mini Drill Chuck with no issues. OCtoolguy 1 Quote
OCtoolguy Posted November 9, 2021 Report Posted November 9, 2021 13 minutes ago, Denny Knappen said: Ray, I use a micro chuck head on the drill press at home. Here at ArtCrafters, use the Dremel. Can you tell me more about the micro chuck? I'm looking at Amazon right now but not finding what I want. Quote
OCtoolguy Posted November 9, 2021 Report Posted November 9, 2021 4 minutes ago, Dak0ta52 said: I use a Dremel plunge router also with a #60. I've got the new 4300 Dremel and haven't had any problem with power at a lower speed. If I have areas in the pattern that will accept a larger bit I'll use my drill press. I also have the smaller chuck to adapt my drill press to a smaller bit but found it didn't center as Ray experienced. When I want to use a bit in my drill press that is smaller than what it will clamp, I'll wrap a small copper wire around the base of the small bit and insert it into the drill press chuck. That seems to work pretty good. I've read here on the Village that some folks have better drill press chucks that will close down to zero. I'm hoping to find one of those that will fit my drill press. Quote
Dak0ta52 Posted November 9, 2021 Report Posted November 9, 2021 If you check with the manufacture of your drill press they usually have aftermarket chucks with the correct arbor you would need. Some of these will close to zero. If you know what arbor you need you can pull them up on Amazon. Seems the most common arbor is the JT33-MT1 or JT33-MT2 OCtoolguy 1 Quote
OCtoolguy Posted November 9, 2021 Report Posted November 9, 2021 1 minute ago, Dak0ta52 said: If you check with the manufacture of your drill press they usually have aftermarket chucks with the correct arbor you would need. Some of these will close to zero. If you know what arbor you need you can pull them up on Amazon. Seems the most common arbor is the JT33-MT1 or JT33-MT2 I'm looking for that info right now. Quote
Denny Knappen Posted November 9, 2021 Report Posted November 9, 2021 12 minutes ago, OCtoolguy said: Can you tell me more about the micro chuck? I'm looking at Amazon right now but not finding what I want. Sorry, so long ago. I don't know. OCtoolguy 1 Quote
OCtoolguy Posted November 9, 2021 Report Posted November 9, 2021 I just found this one on Amazon. It looks like it will fill the bill. https://www.amazon.com/Jet-561706-TDC-501-Taper-Mount/dp/B0007XXI86/ref=pd_bxgy_1/138-0642384-6364469?pd_rd_w=N3fWf&pf_rd_p=c64372fa-c41c-422e-990d-9e034f73989b&pf_rd_r=PZGZY5R1H934C13MZCKF&pd_rd_r=93e4aa9d-4363-4767-8300-7f71dfb9ea34&pd_rd_wg=AfVwe&pd_rd_i=B0007XXI86&psc=1# Quote
Wichman Posted November 9, 2021 Report Posted November 9, 2021 2 hours ago, carl1 said: I just made a Santa ornament and the actuating lines are narrower then the drill bit needed to start, the smallest i have are 1/16 . If you go smaller how do you get the blade threaded, I can barley get the blade in as is. What am I missing. Not good but here is pic of the ornament. Did you see my post about the wing? To cut the veining I used a FD new spiral 2/0 blade (diameter .031) and drilled pilot holes with a #65 (.035). The #60 drill bit is a little larger (.040) compare those numbers with a 1/16 bit (.0625). I get my blades and drill bits from Flying Dutchman. OCtoolguy 1 Quote
Carl civitella Posted November 9, 2021 Report Posted November 9, 2021 Thanks every one, I have a 4300 dremel with the plunge router and a Razorzip. Never used the tiny bits before. I have to get me some and some very small blades. Then I will get up and try again. Carl Quote
Scrappile Posted November 9, 2021 Report Posted November 9, 2021 2 hours ago, OCtoolguy said: I've read here on the Village that some folks have better drill press chucks that will close down to zero. I'm hoping to find one of those that will fit my drill press. Ray, I have a Jet JDP -17DX Drill Press. The chuck closes all the way. The only info on the chuck itself says "1 - 16mm JT3". Here is the manual for the DP. It has a Parts list in it, don't know how much info it gives.. I haven't got time to research it right now, I am just taking a break from trying to repair my clothes washer... Don't know what the heck I am doing, but I am giving it a try... DP manual: 354173_man_EN.pdf OCtoolguy 1 Quote
Fab4 Posted November 9, 2021 Report Posted November 9, 2021 Hi Carl I do all of my hole drilling with my dremel which I hold in my hand No stand or drill press required. I do have a nice big drill press but it's quicker for me doing it by hand - The Dremel will hold all of the small drill bits that are mentioned above Fab4 Greatgrandpawrichard 1 Quote
OCtoolguy Posted November 10, 2021 Report Posted November 10, 2021 (edited) 1 hour ago, Scrappile said: Ray, I have a Jet JDP -17DX Drill Press. The chuck closes all the way. The only info on the chuck itself says "1 - 16mm JT3". Here is the manual for the DP. It has a Parts list in it, don't know how much info it gives.. I haven't got time to research it right now, I am just taking a break from trying to repair my clothes washer... Don't know what the heck I am doing, but I am giving it a try... DP manual: 354173_man_EN.pdf 765.06 kB · 1 download Been there and done that. This last time around, it was something that I couldn't fix. I needed some way to test out the electronics. Turned out to be the motor controller. If I have known that, I could have saved the repair charge and about $100 on the cost of the part. Oh, and thanks for your input on the drill press. I found a chuck that will fit mine and it closes to zero. Now I just have to figure out if it's worth the $50. Edited November 10, 2021 by OCtoolguy Quote
Norm Fengstad Posted November 10, 2021 Report Posted November 10, 2021 I use the Seyco Scrollers drill most of the time it handles the micro bits very very well and these small bits will last much longer in the this little drill versus drill press or hand drill. . Roberta Moreton 1 Quote
TAIrving Posted November 10, 2021 Report Posted November 10, 2021 The OP was asking about saw blades for the smaller holes. The answer is smaller blades. For this problem I went to Pegas MGT 1 and MGT 2.0 blades. The answer is to pick the right drill bit for the pattern feature and then pick the corresponding drill bit. I can't find it, but somebody had posted a chart of drill bit size for each of the blades. Quote
Rolf Posted November 10, 2021 Report Posted November 10, 2021 (edited) On 11/10/2021 at 7:52 AM, Algae said: The OP was asking about saw blades for the smaller holes. The answer is smaller blades. For this problem I went to Pegas MGT 1 and MGT 2.0 blades. The answer is to pick the right drill bit for the pattern feature and then pick the corresponding drill bit. I can't find it, but somebody had posted a chart of drill bit size for each of the blades. I have a couple of things to add. This Pegas blade chart has the suggested drill bit for each blade size. I also have a big drill bit chart on my shop wall that lists all bits number, fraction and metric. To me that is a must have for what I do. The smallest bit I use is a #70 (.028") for when I do beveled inlays. All of the really small bits should be used in a drill press or they will break. I do a lot of stack cutting and have a dedicated Micro Mark drill press. As for the Micro chucks not all are created equal You get what you pay for. Some of these small chucks have a serious runout. I did go nuts and replace my Delta 16" floor model drill press with the most awesome tool in my basement. It has a chuck that goes from 5/8 to at least a #67 (.032") and the drill is quiet, no vibration as there are no belts and a speed range all the way up to 5500 rpm, great for small bits. I usually run the small bits at 3000. PegasChart.pdf Edited November 14, 2021 by Rolf Mark SW 1 Quote
NC Scroller Posted November 10, 2021 Report Posted November 10, 2021 19 hours ago, OCtoolguy said: I have numbers 56-60 and use the #58 the most. My problem is that I bought a 3 jaw adapter for my drill press and I can't get the bit to "center" in the chuck. My drill press is pretty tight so I know the problem is the tiny chuck. Any advice? I get pretty good job from my Dremel plunge router but it spins so fast it burns up the bits. If I slow it down, it has no power. Ray I put a Jacobs 41 BA chuck in my drill press. Got it from eBay. It was under $30. That chuck goes down to zero and does handle all the numbered bits. OCtoolguy and Rolf 1 1 Quote
NC Scroller Posted November 10, 2021 Report Posted November 10, 2021 20 hours ago, carl1 said: I just made a Santa ornament and the actuating lines are narrower then the drill bit needed to start, the smallest i have are 1/16 . If you go smaller how do you get the blade threaded, I can barley get the blade in as is. What am I missing. Not good but here is pic of the ornament. For the detailing lines I would use a 2/0 or smaller blade and a corresponding numbered drill bit per the blade manufacturing company's recommendation. OCtoolguy 1 Quote
Karl S Posted November 10, 2021 Report Posted November 10, 2021 I put one of these on my drill press about five years ago and am very well pleased 0.0005 runout nad never a problem gripping the smallest bit. Pay the (Very reasonable) price and cry no more. From the little machine shop. OCtoolguy 1 Quote
kmmcrafts Posted November 10, 2021 Report Posted November 10, 2021 So, since this is about blades and drill hole sizes.. I'll put in my two penny's worth, LOL I buy only a 56, 58, and 60 drill bits.. here is something I've learned about the hole size and the blade.. I mostly use Pegas MFG blades and mostly size #3 and #5.. same with FD-UR blades.. The Pegas blades require a bit larger hole.. apparently the blade ends are a bit larger than the blade teeth area? Anyway if I'm doing fine veining detail.. I do not use a Pegas blade because I have to start with a bigger hole and the kerf is small.. I do use a Pegas IF I'm going to be going back over the cut with a spiral blade to widen the kerf.. but if I'm not going to be widening the kerf then the FD-UR blade has a wider kerf to closer match the hole drilled.. I can't remember for sure now what size bit is recommended for the #3 Pegas.. but that drill bit hole won't fit for a #5 Pegas but will fit a #5 FD-UR.. which has a wider kerf than the Pegas #3.. Hope I made sense to you all on this.. This is why I keep and use several brands of blades.. Pegas is my main cutting go to blade.. however in cases like this.. I do use FD or Olsen blades for certain things.. to get better results in the details of the project. Rolf, preprius and OCtoolguy 2 1 Quote
Woodrush Posted November 10, 2021 Report Posted November 10, 2021 On 11/9/2021 at 2:52 PM, OCtoolguy said: I have numbers 56-60 and use the #58 the most. My problem is that I bought a 3 jaw adapter for my drill press and I can't get the bit to "center" in the chuck. My drill press is pretty tight so I know the problem is the tiny chuck. Any advice? I get pretty good job from my Dremel plunge router but it spins so fast it burns up the bits. If I slow it down, it has no power. I have to run my Dremel plunge on the lowest speed OCtoolguy 1 Quote
