46 minutes ago, Woodrush said:
I have to run my Dremel plunge on the lowest speed
You must have one of the high end dremels.. mine's just a cheapy and it won't even spin without a load on the first couple speed settings, 😂
13 minutes ago, OCtoolguy said:
The lowest speed on mine is only good for the 1st 1/4".
I got an old knock off that is way better then my real Dremel. I stack 2 1/4 BB and use #66 on low speed and it doesn't bog. I'll be sad when it dies. It's got over 15000 holes so far
Edited by Woodrush
I use a #64 drill bit for all my work.   I use this little chuck   https://mikesworkshop.com/collections/accessories/products/mini-drill-chuck-with-4-collets  but I cut that long shaft off, and just chuck up the solid part.  But I almost always use a #2/0R blade. If I go bigger, I have another of those little chucks with a 1/16" drill bit in it, but I really only find myself using it for drilling for the final outside cut, or for a cut if I'm cutting like 3/4" ply for silhouette shapes that will be painted.
