15 minutes ago, old sarge said:
When I joined I said would look for an item or two that I made since I generally gave away all my little projects and post a photo.  I found one and ran into a server error trying to post.  I would appreciate any advice you folks can give. Thanks.
Can you give us an idea of how you are trying to post pics? It's really easy if you select the "add files" link and then point to where the pic is.
14 minutes ago, old sarge said:
I click on choose files, and then I select the file/photo.  It works well on the bbq forums I belong to. I will keep trying.  Maybe it is an intermittent error. Thanks.
It sounds like you are doing it right. Maybe send a PM to Travis and he can straighten out the problem. I've not gotten a "server error" message before.
1 hour ago, old sarge said:
Here is the little project I did so many years ago when I first got the Excalibur.  I have improved considerably over the years.  It was cut from 1/8 inch Luan.
Well, that looks pretty good to me. How can you improve on near perfection?
1 hour ago, Wichman said:
Looks like you got it figured out. What was the problem?
I used the same procedure that had worked elsewhere and tried to upload the file. Out of frustration I moved the file to photos, thendragged the photo (not the file) from iPhoto. It worked. Guess I am just slowing down.
