red river Posted November 24, 2021 Report Posted November 24, 2021 (edited) I am running out of shelf space to display my scrolled portraits in the living room, so I figure the walls in the living room are my next best bet. However, I can't mar the walls in any way or I'm gonna get a whoopin. What do y'all suggest. I'm thinking a good brand of double sided tape. Some may be in lightweight frames and some may be just 1/8 or 1/4 in. BB ply with a 1/8 BB backer or poster board backer. Any suggestions? Thanx in advance....Forrest Edited November 24, 2021 by red river OCtoolguy 1 Quote
don in brooklin on Posted November 24, 2021 Report Posted November 24, 2021 (edited) I use the 3m velc0r strips and they come in different strength. I have a few intarsia projects on the wall and every thing is fine. Edited November 25, 2021 by don in brooklin on Dan, lawson56, Wichman and 2 others 4 1 Quote
lawson56 Posted November 24, 2021 Report Posted November 24, 2021 I can't remember the name of them but the slogan is Do No Harm. If you want to move the hangar you just peal and go. I have never used them, I have heard they hold a lot. OCtoolguy 1 Quote
redwine Posted November 25, 2021 Report Posted November 25, 2021 (edited) The Command strips is one of the best ways to "hang" your cuttings on a wall! I have been recommending to customers that have asked why I do not have wall hangers on crosses, framed projects, etc, and I tell them about the Command strips that will hold the item to a wall and if later on they want to remove it or move it to another place it is very easily done. I have different pictures of different sizes and weights attached to the walls and have not had any problems with them staying put! Just do as the instructions say to do and you will not have any problems! Erv Edited November 25, 2021 by redwine left out word OCtoolguy and Wichman 1 1 Quote
red river Posted November 27, 2021 Author Report Posted November 27, 2021 I'm going to give the 3M Command Strips a shot. Thanks for the replies. I hope everyone had a good Thanksgiving......forrest OCtoolguy 1 Quote
FrankEV Posted November 27, 2021 Report Posted November 27, 2021 3M Command strips are good. However, I have found that when left on the wall for an extended period of time (as little as a month), the removable function seems to go away. Trying to remove the strip can actually cause extensive damage to the wall surface...this happended to me when hanging Xmas decorations for just the month of December a few years ago. For most of our Scroll Saw Portraits, even when in a frame, they are very light. I use the very small sawtooth hangers on the back of my work and use very tiny small headed brass nails to hang my work. The hole that remains when removed is very tiny, almost invisible and easily filled with the smallest dab of spackle if and when necessary. If you are displaying your work in your living room, they will probably be there a long time...not sure, IMHO, I would use any kind of adheisive hanger. John B and OCtoolguy 1 1 Quote
John B Posted November 28, 2021 Report Posted November 28, 2021 (edited) I would have to agree with Frank here. Any of the "Sticky" type hanger tend to become permanent after a while and can severely damage your wall when being removed. They have a knack of pulling paint of, with them. My go to is the Gyprock style hangers, they only leave a very small pin hole when removed. Edited November 28, 2021 by John B Quote
old sarge Posted November 28, 2021 Report Posted November 28, 2021 If the wall is flat as in not textured, and the backs of the portraits are flat, one of the varieties of nano tape might work. There are many brands out there and I have never tried any of them. https://www.casetrick.com/products/nano-tape Quote
red river Posted November 29, 2021 Author Report Posted November 29, 2021 I'm going to give the 3M Command Strips a shot. Thanks for the replies. I hope everyone had a good Thanksgiving......forrest Thank y'all for giving me several options, I am going to get some small brass nails and sawtooth hangers too. Quote
redwine Posted November 30, 2021 Report Posted November 30, 2021 When you remove the strip that is on the wall, you have to be sure that you pull that tab strip down flat against the wall. If you pull on it like you would tape it will take the the paint off with it. That strip will become longer as you pull down on it and the tendency is to pull it off than, don't do it! Keep pulling it down, it will release without taking the paint with it. I have not had any problems with removing the strips that have been on the walls for a year or more! Erv Quote
