Have any of you used the single direction bevel cutting technique? I've seen this technique is Spielman's books using it for letters; the bevel is the same for all the cuts, i.e. left, right and a spiral blade must be used. This gives the letters a shadow effect. I'd like to try it on a couple of project and don't want to reinvent the wheel.
Thanks in advance.
Oh with some more thought and imagination, I can see how a spiral blade needs to be used....
Keep letters oriented bottom toward you.   Angle the table to left or right.
When cutting the sides of the letters without spinning the wood, the letters will be angled.
When cutting the top you don't spin the wood. You just use side of spiral blade to go across top and bottom.
Thanks you got me thinking.😃
  • 2 weeks later...
blade 2/0.
My thought is the slant is need to be more on thinner wood. The thicker the wood the less angle.
The camera is over the "I" (above).  So that shows the slant.
Here is more pics.  Alien is centered, then the "I" is centered.
Edited by preprius
added pic and descriptions.
  • 1 month later...
Yes the 25 deg gives it a better emphasis of 3d.
You can use it on letters on plaques.  Left side of plaque with right tilt, and on the right side of plaque left tilt.  So when viewing the plaque the viewer see emphasized perpective.
How are you going to use this technique?
Me.
Mark Eason
