4 hours ago, preprius said:
On both the whiskers look like some of the wood would fall out.  Are some of the whiskers painted on?
No, none are painted on.  The leopard wiskers are all cut outs.   The Kitten wiskers are surface mounted.  I did lose one that I did not bother to try to fix. Another is actually broken but glued into place.  The Kitten was a difficult piece to cut.
2 hours ago, Dak0ta52 said:
Beautiful work as usual, Frank. I'm sure the kitten required a lot of spinning on the table if you cut that with a straight blade.
Yes, lots and lots of spining.  I first tried with a spiral blade but just could not get the points and pointy interior intersections sharp enough.  Using the regular blades, in some areas I did the double cut to get into the interior points, but mostly cut spin cut spin, etc.
