Popular Post RabidAlien Posted December 20, 2021 Popular Post Report Posted December 20, 2021 Got the large version cut in one day, took several to sand, finish, and assemble. Sanded the gears a little bit more than the two spacers, so they sit a very small fraction of an inch lower than the spacers, giving them more freedom to spin. That made them a LOT easier to move. WolfmoonCT, TexasDIY, jollyred and 10 others 13 Quote
barb.j.enders Posted December 20, 2021 Report Posted December 20, 2021 Very nice. I cut the small one, stack 3. Put one together but never got a finish on it. Did you finish the parts separately or after it was assembled? What did you use to finish? RabidAlien 1 Quote
RabidAlien Posted December 20, 2021 Author Report Posted December 20, 2021 I finished them all, then assembled. Well...technically....I assembled to check fits and use a round file on the inside of the axle hole on the gears so they would spin smoothly, but not bind. Once I knew the posts were the right height (more or less) and the gears spun relatively freely (wood on wood, so its not going to be fidget-spinner frictionless), I pulled it apart, glued the posts into the lower piece, stained everything (hearts/spacers are Minwax "Early American" and the gears are Minwax "Weathered Oak"....I need to restock my stains!). Once dry, I reassembled and glued on the top heart. barb.j.enders 1 Quote
namunolie Posted December 20, 2021 Report Posted December 20, 2021 9 hours ago, RabidAlien said: Got the large version cut in one day, took several to sand, finish, and assemble. Sanded the gears a little bit more than the two spacers, so they sit a very small fraction of an inch lower than the spacers, giving them more freedom to spin. That made them a LOT easier to move. Beautiful work ! ❤ preprius and RabidAlien 1 1 Quote
