Popular Post FrankEV Posted December 31, 2021 Popular Post Report Posted December 31, 2021 I found this free stencil pattern on-line. I converted it into a scroll saw pattern and sized it to fit a 5/32” x 10” x 11” Solid Core Maple cut panel that was affixed to a hand painted ¼” x 12” x 13” BB ply backer. All cutting completed with Pegas #2/0 Spiral blades The colored portion of the backer was painted with Artist Acrylic paints while the 1” wide perimeter mat area of the backer was painted rattle can spray Chocolate Brown for a strong contrast with the natural Maple panel. As usual, I protected the finished panel with multiple coats of Deft Clear Spray Gloss Lacquer. Once again, the panel is set loose in a 1 3/4” wide Poplar Frame stained with Minwax Honey Maple and protected with multiple coats of Minwax Clear Gloss Wipe on Poly. I plan to remake the frame for this piece as I am unhappy with the corner miter joints. Comments and Critique welcome. Joe W., Woodrush, preprius and 15 others 17 1 Quote
Eric67 Posted December 31, 2021 Report Posted December 31, 2021 Superbe Frank, bravo ! FrankEV and danny 1 1 Quote
Jim Blume Posted December 31, 2021 Report Posted December 31, 2021 Great job all around, Guaranteed you have more patience than I to do all those colors underneath. But the results are certainly worth the effort. danny and FrankEV 1 1 Quote
FrankEV Posted December 31, 2021 Author Report Posted December 31, 2021 1 hour ago, Jim Blume said: Great job all around, Guaranteed you have more patience than I to do all those colors underneath. But the results are certainly worth the effort. This one was very challenging as the cuts were so close to each other. I use additional copies of the printed pattern to make rough painting stencils, but it is still not easy getting the colors in the correct locations. I also play with shading of the larger areas to get different colors in different areas without worring where the exact cut lines are. Thanks for the kind words. Jim Blume and danny 2 Quote
munzieb Posted December 31, 2021 Report Posted December 31, 2021 Frank, that is absolutely stunning. A masterwork! FrankEV and danny 1 1 Quote
Jim Blume Posted December 31, 2021 Report Posted December 31, 2021 1 hour ago, FrankEV said: This one was very challenging as the cuts were so close to each other. I use additional copies of the printed pattern to make rough painting stencils, but it is still not easy getting the colors in the correct locations. I also play with shading of the larger areas to get different colors in different areas without worring where the exact cut lines are. Thanks for the kind words. I really love what you did there. I have a fondness for paper cut patterns, but when I modify them to make them scrollsaw friendly, they are the same in regards to close and narrow lines. But again, If I cut that I would certainly be proud to call it my own. FrankEV 1 Quote
Dak0ta52 Posted January 1, 2022 Report Posted January 1, 2022 Definitely scroll saw artistry! Fantastic piece, Frank. FrankEV 1 Quote
wombatie Posted January 1, 2022 Report Posted January 1, 2022 That is amazing. Your best one yet I think. Marg FrankEV 1 Quote
don watson Posted January 1, 2022 Report Posted January 1, 2022 This could be the best you have done yet Frank. Truly amazing and extremely colourful piece of art. FrankEV 1 Quote
daveww1 Posted January 1, 2022 Report Posted January 1, 2022 it's beautiful, amazing job FrankEV 1 Quote
Fish Posted January 1, 2022 Report Posted January 1, 2022 That is amazing! Beautiful work FrankEV 1 Quote
