When I'm doing a lot of Sheila's designs for candle trays lately, they have thin decorative pieces that go on them. They are cut from 1/8" thick wood.. sometimes if it's all painted, it's ply, if it's just stained, it's the same wood as what the tray is made from.
Most of these are very small, and I get a lot of chattering and have broken a few pieces (which usually break clean and can be glued back together and you can't even tell it broke). I've been using a #2/0 reverse tooth blade on slow speed. Do any of you think I should try to use just regular tooth for the thin stock, so that I don't have to worry about the up cut on a reverse tooth?
The thread your talking about Brett, "Using More Blade" . Its back on page 3. (Sorry I'm not good at bringing up links) Its a piece of Melamine made to fit the scroll saw table. Hope this helps.
Marg
