Popular Post Rolf Posted January 12, 2022 Popular Post Report Posted January 12, 2022 (edited) Huge thank you to Frank EV!! I saw this Frank EV. design and new that I had to cut it. I absolutely love it. It is cut from 3/4 maple and the base is black walnut. Pegas MGT 1 and cut the base at 10 degrees. I did some shaping like I was doing Intarsia. For the internal shaping I used a Rampower hand piece with assorted burrs and small sanding drums. Pegas MGT 1 and cut the base at 10 degrees. Two coats of Danish oil and then a couple of coats satin wipe on poly just to add some highlights. This is the darkest black walnut I have ever seen. From a neighbors tree. Edited January 12, 2022 by Rolf stoney, bobscroll, Roberta Moreton and 21 others 21 3 Quote
CSull Posted January 12, 2022 Report Posted January 12, 2022 Wow, that is beautiful! OCtoolguy 1 Quote
OCtoolguy Posted January 12, 2022 Report Posted January 12, 2022 3 hours ago, Rolf said: Huge thank you to Frank EV!! I saw this Frank EV. design and new that I had to cut it. I absolutely love it. It is cut from 3/4 maple and the base is black walnut. Pegas MGT 1 and cut the base at 10 degrees. I did some shaping like I was doing Intarsia. For the internal shaping I used a Rampower hand piece with assorted burrs and small sanding drums. Pegas MGT 1 and cut the base at 10 degrees. Two coats of Danish oil and then a couple of coats satin wipe on poly just to add some highlights. This is the darkest black walnut I have ever seen. From a neighbors tree. Excellent piece of work! Very well done. CharleyL, FrankEV and Jim Blume 3 Quote
munzieb Posted January 12, 2022 Report Posted January 12, 2022 A wonderful job! Love the color and texture of the wood especially the finish. OCtoolguy 1 Quote
WayneMahler Posted January 12, 2022 Report Posted January 12, 2022 Absolutely gorgeous OCtoolguy 1 Quote
merlin Posted January 12, 2022 Report Posted January 12, 2022 Very nice Rolf...Did you sand both sides..I did on mine (not yet finished) but seeing your dark walnut base I my just change what I'm doing.. Oh well more work, but I have to finish the lean to for the workshop first.... Merlin... OCtoolguy 1 Quote
Dak0ta52 Posted January 12, 2022 Report Posted January 12, 2022 Beautiful piece Rolf. I'll most likely cut this in the future but am certain it won't turn out as nice as your piece. OCtoolguy 1 Quote
Rolf Posted January 12, 2022 Author Report Posted January 12, 2022 (edited) 18 hours ago, merlin said: Very nice Rolf...Did you sand both sides..I did on mine (not yet finished) but seeing your dark walnut base I my just change what I'm doing.. Oh well more work, but I have to finish the lean to for the workshop first.... Merlin... Yes I did shape both sides, that way I can face it either way. I am setup for serious Intarsia shaping so it doesn't take that much extra time. the smaller areas do take time. Edited January 13, 2022 by Rolf OCtoolguy 1 Quote
rdatelle Posted January 12, 2022 Report Posted January 12, 2022 That came out great.Beautiful finish to. OCtoolguy 1 Quote
Dan Posted January 12, 2022 Report Posted January 12, 2022 Excellent execution of the project. OCtoolguy 1 Quote
wombatie Posted January 13, 2022 Report Posted January 13, 2022 That is so beautiful. You did an excellent job. Marg OCtoolguy 1 Quote
rustynail Posted January 13, 2022 Report Posted January 13, 2022 Looking good, great work... OCtoolguy 1 Quote
NC Scroller Posted January 13, 2022 Report Posted January 13, 2022 Great use of different processes and techniques. CharleyL and OCtoolguy 2 Quote
daveww1 Posted January 13, 2022 Report Posted January 13, 2022 awesome job, it's beautiful OCtoolguy 1 Quote
John E. Posted January 13, 2022 Report Posted January 13, 2022 Rolf that is gorgeous! I just joined this group. Can you tell me how to finding the pattern? Cheers! OCtoolguy 1 Quote
meflick Posted January 13, 2022 Report Posted January 13, 2022 8 minutes ago, John E. said: Rolf that is gorgeous! I just joined this group. Can you tell me how to finding the pattern? Cheers! It was shared by @FrankEV in the patterns subforum here in the Village. There are two different patterns in that post. This one is the first two labeled Two Heads Sculpture Matt B and OCtoolguy 2 Quote
John E. Posted January 13, 2022 Report Posted January 13, 2022 Thanks very much meflick, Rolf, and Frank EV. John E. meflick and OCtoolguy 2 Quote
FrankEV Posted January 13, 2022 Report Posted January 13, 2022 (edited) Rolf, You did the pattern proud!!! It is wonderful to see someone elses take on a pattern I made available. Very nicely done. I do like the bevel on the base. Adds a little bit more class to the overall piece. Your original post would have been more appropriate in "Bragging Rights". A project to really brag about! Edited January 13, 2022 by FrankEV Jim Blume, John E. and OCtoolguy 3 Quote
John B Posted January 15, 2022 Report Posted January 15, 2022 You sure belted that one over the stands mate. Absolutely beautiful Truly love the softening of the edges OCtoolguy 1 Quote
