Popular Post FrankEV Posted January 14, 2022 Popular Post Report Posted January 14, 2022 (edited) This paper-cut pattern I found on-line caught my eye. The pattern itself did not need much work to make it scrollable although I made a lot of edits as I was cutting due the line work being very close together and I needed stronger bridges in many places. I have no plans to incorporate the edits into my reworked pattern. I sized it to fit a 5/32” x 15” x 10” Solid Core Maple Panel which was affixed to a Hand Painted ¼” x 17” x 12” BB Ply Backer. The actual pattern contained a lot of Vein like cuts that formed the images, but they did not open well to the backer, even though I used a very large Pegas #1 Spiral blade. As a result, I found it necessary to embellish the images by also coloring the cut panel abstractly. Other areas were cut using Pegas #2/0 Spiral blades. As always, the assembled panel was protected with multiple coats of Deft Clear Gloss Lacquer. The panel is set loose in a 1 3/4” wide Poplar Frame finished with Black Lacquer. I’m liking the very clean uniform black high gloss finish I obtain with the Rust-Oleum spray can Black Lacquer. I’m in a learning curve as the application is more difficult than paint or a Stain/Poly to get a nice uniform finish without runs or blemishes. There is one annoying problem with the Black Lacquer finish. It is hard to photograph because of glare reflections. This was the third project that I was doing simutaneously with Splat Cat and Trees of Green. The painting process was time consuming. Comments and Critique welcome. Edited January 15, 2022 by FrankEV Spelling correction new2woodwrk, JAC1961, TripleJScroller and 12 others 15 Quote
CSull Posted January 14, 2022 Report Posted January 14, 2022 Another fine piece Frank! I have become fond of using spiral blades after detesting them at first, I think they work really well when veining pieces. FrankEV 1 Quote
Dak0ta52 Posted January 14, 2022 Report Posted January 14, 2022 Excellent work, Frank. Especially while having to modify a pattern as you cut. FrankEV 1 Quote
wombatie Posted January 15, 2022 Report Posted January 15, 2022 That is very pretty. The colors you chose are excellent. Top notch cutting too. Marg FrankEV 1 Quote
daveww1 Posted January 15, 2022 Report Posted January 15, 2022 fantastic job, the colors are beautiful FrankEV 1 Quote
barb.j.enders Posted January 15, 2022 Report Posted January 15, 2022 Stunning - love the colouring. FrankEV 1 Quote
danny Posted January 19, 2022 Report Posted January 19, 2022 I do Enjoy looking at All your Crafts, but Especially ones like this one. Reason is I KIND OF DO REMEMBER WHAT YOU SAID ABOUT YOUR WAYS to color such projects. Always has Amazed me. Do you have a Tutorial kind of on your Steps? You have been mostly the reason that I have started using color in some of my crafts. Anyway this is just Another of your Amazing Crafts. Danny :+} preprius and FrankEV 1 1 Quote
bobscroll Posted January 20, 2022 Report Posted January 20, 2022 Hi Frank, That will brighten any body's room up! Beautiful to look at, Thank you for showing Bob FrankEV 1 Quote
munzieb Posted January 20, 2022 Report Posted January 20, 2022 You hit another one out of the park! Amazing! FrankEV 1 Quote
rdatelle Posted January 20, 2022 Report Posted January 20, 2022 Another great job Frank. A little more than I can handle. FrankEV 1 Quote
