NC Scroller Posted January 15, 2022 Report Posted January 15, 2022 Anyone recognize this pattern and know where it is available? TexasDIY, jbrowning, OCtoolguy and 1 other 4 Quote
barb.j.enders Posted January 15, 2022 Report Posted January 15, 2022 Don't recognize it but would also be interested in the pattern! jbrowning and OCtoolguy 2 Quote
rjweb Posted January 15, 2022 Report Posted January 15, 2022 Hope someone finds the pattern I also would like to cut it, RJ OCtoolguy and jbrowning 2 Quote
OCtoolguy Posted January 15, 2022 Report Posted January 15, 2022 That one would be very easy to photograph and trace over. Nothing but straight lines. crupiea, NC Scroller and danny 3 Quote
Dan Posted January 15, 2022 Report Posted January 15, 2022 I agree, just make your own. May look cool with different wood for the pieces. NC Scroller, OCtoolguy and danny 3 Quote
meflick Posted January 16, 2022 Report Posted January 16, 2022 @namunolie does similar type puzzles. I checked his Etsy store but don’t see this one there though. https://www.etsy.com/shop/Namunolie?page=1#items NC Scroller and OCtoolguy 2 Quote
OCtoolguy Posted January 16, 2022 Report Posted January 16, 2022 (edited) I'm not quite understanding what the two are about. I understand the top one but what's puzzling about the star? Never mind, I went back and now see that it's a puzzle that holds the pieces that are then supposed to be put into a star. Great idea. I might have to make one. Edited January 16, 2022 by OCtoolguy Quote
Fab4 Posted January 16, 2022 Report Posted January 16, 2022 17 hours ago, OCtoolguy said: That one would be very easy to photograph and trace over. Nothing but straight lines. Hi Ray: Go ahead and make a pattern, would love to see it. Thanks Fab4 OCtoolguy 1 Quote
JimErn Posted January 16, 2022 Report Posted January 16, 2022 enjoy don watson, OCtoolguy, barb.j.enders and 5 others 4 4 Quote
NC Scroller Posted January 16, 2022 Author Report Posted January 16, 2022 Jim, UDAMAN!!! Thanks OCtoolguy 1 Quote
OCtoolguy Posted January 16, 2022 Report Posted January 16, 2022 5 hours ago, Fab4 said: Hi Ray: Go ahead and make a pattern, would love to see it. Thanks Fab4 Working on it. Fab4 1 Quote
OCtoolguy Posted January 16, 2022 Report Posted January 16, 2022 3 hours ago, JimErn said: enjoy Still need the other half Jim. Quote
Fab4 Posted January 16, 2022 Report Posted January 16, 2022 (edited) Ray: The 2 examples that Scott showed at the beginning of this post are 2 separate pieces They do not go together - The star one is a partial cutting, It's missing the star that is cut into puzzle pieces - The shape for both just happens to be the same, this is what is throwing you off BUT: If you do manage to fit the pieces from the top one into the star, make sure you keep the solution it will surely be a one of kind So what you and Jim did is the actual pattern for the top photo Thanks Fab4 Edited January 16, 2022 by Fab4 OCtoolguy 1 Quote
OCtoolguy Posted January 16, 2022 Report Posted January 16, 2022 (edited) 14 minutes ago, Fab4 said: Ray: The 2 examples that Scott showed at the beginning of this post are 2 separate pieces They do not go together - The star one is a partial cutting, It's missing the star that is cut into puzzle pieces - The shape for both just happens to be the same, this is what is throwing you off BUT: If you do manage to fit the pieces from the top one into the star, make sure you keep the solution it will surely be a one of kind So what you and Jim did is the actual pattern for the top photo Thanks Fab4 Edited January 16, 2022 by OCtoolguy Quote
trackman Posted January 17, 2022 Report Posted January 17, 2022 So you have to cut the top one an also have to cut a star for the top pieces to fit into?? OCtoolguy 1 Quote
Fab4 Posted January 17, 2022 Report Posted January 17, 2022 (edited) 11 hours ago, trackman said: So you have to cut the top one an also have to cut a star for the top pieces to fit into?? Edited January 17, 2022 by Fab4 Quote
John B Posted January 17, 2022 Report Posted January 17, 2022 3 hours ago, Fab4 said: Hi Delvaughn: I don't think so, I think it's 2 separate patterns - Maybe someone else can weigh in and confirm Fab4 I believe so. I haven't gone as far as digitising the pieces and then fitting them in the star star shape, but the shape of the pieces certainly suggests that they will fit in the star. Also the grain direction does not match on the pieces in the pentagon, suggesting that they have been cut from another shape. The grain looks suspiciously like the star. OCtoolguy 1 Quote
Fab4 Posted January 17, 2022 Report Posted January 17, 2022 11 hours ago, OCtoolguy said: Hi Ray: Whatever you were going to say, I agree - I'm wrong in what I wrote - You do need the star and these pieces will fit into that star This whole thread is becoming very puzzling Fab4 John B, NC Scroller and OCtoolguy 2 1 Quote
Fab4 Posted January 17, 2022 Report Posted January 17, 2022 1 hour ago, John B said: I believe so. I haven't gone as far as digitising the pieces and then fitting them in the star star shape, but the shape of the pieces certainly suggests that they will fit in the star. Also the grain direction does not match on the pieces in the pentagon, suggesting that they have been cut from another shape. The grain looks suspiciously like the star. Hi John: I retract what I wrote before, I was wrong, you are correct, these pieces will fit or make a star shape Fab4 John B and OCtoolguy 2 Quote
kmmcrafts Posted January 17, 2022 Report Posted January 17, 2022 Cut the one you made pattern for and then make the star and trace around it to make the pattern for the second star.. that'll be the challenge.. OCtoolguy 1 Quote
NC Scroller Posted January 17, 2022 Author Report Posted January 17, 2022 I believe it is one puzzle made up of three layers glued together. The top is pentagon with the odd pieces. The bottom is the star. The middle is solid. OCtoolguy 1 Quote
JimErn Posted January 17, 2022 Report Posted January 17, 2022 Sorry about that, forgot the bottom image Fab4, bobscroll, John B and 2 others 3 2 Quote
Dan Posted January 17, 2022 Report Posted January 17, 2022 Well, I think I figured it out. Yes, you can take the pieces from the pentagon and arrange them in the star. One piece from the star will need to be flipped over to finish the octagon. I printed the star and octagon and cut them out. Now I think I will make one. Thanks for all of your thoughts and inputs. And thanks Jim for the pattern. It's pretty cool. I'll post a photo of the paper cutout, but first I'll let you guys try it. Fab4, John B and OCtoolguy 1 1 1 Quote
Dan Posted January 19, 2022 Report Posted January 19, 2022 Here's what I found is the best fit. This is cut from paper so I'm not sure if it will work when cut from wood, but I may try it and share results. The white piece was flipped to fit. The center piece may also fit better if flipped. OCtoolguy, barb.j.enders, Fab4 and 1 other 3 1 Quote
