I would say that's just right. You did a great job on it. One thing to do before cutting it out, print your pattern full size and closely look at it. Is there any areas that are too tight for you? If so, circle the area with a red pen, then go back and fix the potential problems. If everything looks OK, cut it out. I look forward to seeing the finished project.
Great advice from Travis. I always look over the pattern very carefully and mark any difficult areas with a red arrow or circle to remind me to be extra carefull when I get to them. I would cut the inner cuts of her teeth before going around the outside of them. Great pattern. :thumbs:
Mick
