Dak0ta52 Posted February 15, 2022 Report Posted February 15, 2022 I was constantly having trouble with the blade clamps on my WEN scroll saw either slipping or completely coming loose when cutting. The original knobs that came on the saw broke within the first couple weeks because I had to "over tighten" just to keep the blades from slipping. I tried roughing the clamping area of the clamps with sandpaper and that helped some but again, the slipping returned. Eventually, having to tightened the clamps so much to try to get them to hold, the threads of the clamp would strip. I started using a regular bolt and a nut driver to tighten the clamps. I made knobs but trying to tighten them by hand was no sufficient enough to hold. The original blade clamps use a M4-.07 bolt/thread. I drilled and tapped a clamp with a #10-24 and made another knob. So far it has been working fine. The coarser thread tightens faster and you don't have to turn and turn and turn to get the clamp to close onto the blade. Clamps can be purchased through WEN for about $5 each. I've ordered a half dozen and will use them until I start having problems with slippage. Then I'll drill and tap to uses with the larger, coarser thread. Hope this helps some of the WEN users. My goal is to upgrade saws sometime in the future but for now, this will have to do. OCtoolguy, kmmcrafts, jr42 and 2 others 3 2 Quote
new2woodwrk Posted February 16, 2022 Report Posted February 16, 2022 Which wen is this? The new one or the old pinned one? OCtoolguy 1 Quote
Dak0ta52 Posted February 17, 2022 Author Report Posted February 17, 2022 22 hours ago, new2woodwrk said: Which wen is this? The new one or the old pinned one? This would be the 3922. The 3921 uses the pinned blades and doesn't really need to be clamped. The new WEN saw, 2156, uses a different clamping system if I'm not mistaken. new2woodwrk and OCtoolguy 2 Quote
new2woodwrk Posted February 17, 2022 Report Posted February 17, 2022 5 hours ago, Dak0ta52 said: This would be the 3922. The 3921 uses the pinned blades and doesn't really need to be clamped. The new WEN saw, 2156, uses a different clamping system if I'm not mistaken. I have the 3921 - and it definitely needs a clamping system LOL - I use magnets I was looking at the new Wen but opted not to give it a try although I love the price OCtoolguy 1 Quote
kmmcrafts Posted February 17, 2022 Report Posted February 17, 2022 1 hour ago, new2woodwrk said: I have the 3921 - and it definitely needs a clamping system LOL - I use magnets I was looking at the new Wen but opted not to give it a try although I love the price Someone here on the forums bought one a while ago, they said it was a decent saw but he was using it for thick wood and mentioned the motor seem to bog down.. OCtoolguy and new2woodwrk 2 Quote
