RoyzMG Posted February 25, 2022 Report Share Posted February 25, 2022 Any recommendations for a design of a scroll saw table or pedestal? I currently have my saw on my custom made build table but this requires standing at the saw and trying to manipulate the foot operated on/off switch. Searching the web I found a couple of tables that allow sitting at the saw (my recommendation). I also noticed many designs allow the saw itself to be angled downward to prevent neck strain. I’m new at the scroll saw and have only been using it for about 10 hours but a sitting solution appears to be the answer. OCtoolguy and danny 2 Quote Link to comment Share on other sites More sharing options...
WayneMahler Posted February 25, 2022 Report Share Posted February 25, 2022 I found the a bar stool height is good for sitting. I have used mine for many years. My saw table is normal height and the plans were published in wood magazine. Can't remember which issue but will look if you wish. I did shorten the legs about 2 inches and use a foot control. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted February 26, 2022 Report Share Posted February 26, 2022 I have 2 Excaliburs that I built low tables that are moveable. Each one has 2 7" wheels at the back end opposite from where I sit. I have incorporated a couple of pieces of PVC that slide inside of each other to make wheelbarrow type handles to move the saws around. When not needed the smaller PVC slides inside of the larger PVC. Each saw has it's own onboard dust control system using MetroVac 500 vacuums and mini cyclone dust collectors. All in all, they work out great. There are plans out there but I like mine better. Good luck with whatever you come up with. danny 1 Quote Link to comment Share on other sites More sharing options...
barb.j.enders Posted February 26, 2022 Report Share Posted February 26, 2022 This plan has been mentioned by a number of people in other social media sites. I think Steve Good even mentions it. https://www.etsy.com/listing/398074303/scroll-saw-stand-woodworking-plans?ref=shop_home_active_1 GrampaJim and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
ChelCass Posted February 26, 2022 Report Share Posted February 26, 2022 Here is the work bench hubby made for me. i use a bar stool for sitting plus I have the option of standing if I wish. It has three tilt setting and a shelf below for misc. He measured my saw for the top the saw is bolted to. Works like a charm for me. Made it out of lumber he had on hand. Hope this helps. Roberta Moreton and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
